Skip to main content
ledel
Gold ⭐️
Gold ⭐️
October 17, 2017
Spark: avoiding stack traces when starting spark-shell
  • October 5, 2026 at 9:17 AM
  • 0 replies
  • 2763 views
  • Translate All
When starting spark-shell, it tries to bind to port 4040 for the SparkUI.
If that port is already taken because of another spark-shell session active, it tries then to bind on 4041, then 4042, etc.
Each time the binding didn't suceed, there's a huge WARN stack trace which could be filtered
[user@serv hive]$ SPARK_MAJOR_VERSION=2 spark-shell
SPARK_MAJOR_VERSION is set to 2, using Spark2
Setting default log level to "WARN".
To adjust logging level use sc.setLogLevel(newLevel). For SparkR, use setLogLevel(newLevel).
17/09/20 11:49:43 WARN AbstractLifeCycle: FAILED ServerConnector@2d258eff{HTTP/1.1}
{0.0.0.0:4040}: java.net.BindException: Address already in use
at sun.nio.ch.Net.bind0(Native Method)
at sun.nio.ch.Net.bind(Net.java:433)
at sun.nio.ch.Net.bind(Net.java:425)
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223)
at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:74)
at org.spark_project.jetty.server.ServerConnector.open(ServerConnector.java:321)
at org.spark_project.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:80)
at org.spark_project.jetty.server.ServerConnector.doStart(ServerConnector.java:236)
at org.spark_project.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
at org.apache.spark.ui.JettyUtils$.org$apache$spark$ui$JettyUtils$$newConnector$1(JettyUtils.scala:333)
at org.apache.spark.ui.JettyUtils$.org$apache$spark$ui$JettyUtils$$httpConnect$1(JettyUtils.scala:365)
at org.apache.spark.ui.JettyUtils$$anonfun$7.apply(JettyUtils.scala:368)
To filter that stacktrace, let's put that class log4j verbosity in ERROR level in /usr/hdp/current/spark2-client/conf/log4j.properties
# Added for not having stack traces when binding to SparkUI
log4j.logger.org.spark_project.jetty.util.component.AbstractLifeCycle=ERROR
