Skip to main content
orlandoteixeira
Gold ⭐️
Gold ⭐️
Jan 26, 2026 3:36 PM UTC
When using Java 17 with CDP 7.1.9 SP1 simple Yarn distributed shell job fails when Ldap group mapping turned on
  • Oct 5, 2026 8:36 AM UTC
  • 0 replies
  • 3594 views
  • Translate All
Symptoms Applies to
 New clusters using CDP 7.1.9 SP1 and Java 17 JDK with Ldap group mapping on.
Instructions
Need to add In Yarn - Configuration - search for yarn.nodemanager.admin-env and change the NodeManager Group (all of them if you have more then one) to: JDK_JAVA_OPTIONS=--add-opens=java.base/java.net=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-opens=java.base/java.util.concurrent.atomic=ALL-UNNAMED --add-opens=java.base/java.util.regex=ALL-UNNAMED --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.time=ALL-UNNAMED --add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.base/java.nio=ALL-UNNAMED --add-exports=java.base/sun.net.dns=ALL-UNNAMED --add-exports=java.base/sun.net.util=ALL-UNNAMED --add-exports=java.naming/com.sun.jndi.ldap=ALL-UNNAMED --add-opens=java.naming/com.sun.jndi.ldap=ALL-UNNAMED --add-opens=java.base/java.lang=ALL-UNNAMED --add-exports=java.base/sun.net.dns=ALL-UNNAMED --add-exports=java.base/sun.net.util=ALL-UNNAMED,MALLOC_ARENA_MAX=$MALLOC_ARENA_MAX
