Cannot write Dataframe from Spark to Hive using Hive warehouse connector
I'm trying to work with Spark and Hive for HDP 3.0. As I see in some articles, now we have to use Hive Warehouse Connector. Everything works fine except for one proble.
I can't write a dataframe directlyh from Spark to Hive using Hive Warehouse connector.
I have the following code:
val spark = SparkSession
.builder()
.appName("Spark Hive Test Job")
.config("spark.sql.hive.hiveserver2.jdbc.url", "jdbc:hive2://s01.ndtstu.local:2181,m01.ndtstu.local:2181,m02.ndtstu.local:2181/;serviceDiscoveryMode=zooKeeper;zooKeeperNamespace=hiveserver2;user=hive;password=hive?")
.getOrCreate()
val hive = HiveWarehouseSession.session(spark).build()
hive.createDatabase("testADD", true);
hive.setDatabase("testADD")
hive.createTable("tabletest").ifNotExists()
.column("k", "int")
.column("value", "int")
.create()
import spark.implicits._
val x = Seq((4,4),(5,5)).toDF("k","value")
x.write
.format("com.hortonworks.spark.sql.hive.llap.HiveWarehouseConnector")
.mode("append")
.option("database", "testADD")
.option("table", "tabletest2")
.save()
And I have the following error stack trace:
19/04/16 13:09:37 ERROR WriteToDataSourceV2Exec: Data source writer com.hortonworks.spark.sql.hive.llap.HiveWarehouseDataSourceWriter@7057dbda is aborting.
19/04/16 13:09:37 ERROR HiveWarehouseDataSourceWriter: Aborted DataWriter job 20190416130935-a22961fa-7dee-4eed-a41c-7f67bbf3bdae
19/04/16 13:09:37 ERROR WriteToDataSourceV2Exec: Data source writer com.hortonworks.spark.sql.hive.llap.HiveWarehouseDataSourceWriter@7057dbda aborted.
Exception in thread "main" org.apache.spark.SparkException: Writing job aborted.
at org.apache.spark.sql.execution.datasources.v2.WriteToDataSourceV2Exec.doExecute(WriteToDataSourceV2.scala:112)
at org.apache.spark.sql.execution.SparkPlan$$anonfun$execute$1.apply(SparkPlan.scala:131)
at org.apache.spark.sql.execution.SparkPlan$$anonfun$execute$1.apply(SparkPlan.scala:127)
at org.apache.spark.sql.execution.SparkPlan$$anonfun$executeQuery$1.apply(SparkPlan.scala:155)
at org.apache.spark.rdd.RDDOperationScope$.withScope(RDDOperationScope.scala:151)
at org.apache.spark.sql.execution.SparkPlan.executeQuery(SparkPlan.scala:152)
at org.apache.spark.sql.execution.SparkPlan.execute(SparkPlan.scala:127)
at org.apache.spark.sql.execution.QueryExecution.toRdd$lzycompute(QueryExecution.scala:80)
at org.apache.spark.sql.execution.QueryExecution.toRdd(QueryExecution.scala:80)
at org.apache.spark.sql.DataFrameWriter$$anonfun$runCommand$1.apply(DataFrameWriter.scala:656)
at org.apache.spark.sql.execution.SQLExecution$.withNewExecutionId(SQLExecution.scala:77)
at org.apache.spark.sql.DataFrameWriter.runCommand(DataFrameWriter.scala:656)
at org.apache.spark.sql.DataFrameWriter.save(DataFrameWriter.scala:256)
at test.Test2$.main(Test2.scala:40)
at test.Test2.main(Test2.scala)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.apache.spark.deploy.JavaMainApplication.start(SparkApplication.scala:52)
at org.apache.spark.deploy.SparkSubmit$.org$apache$spark$deploy$SparkSubmit$$runMain(SparkSubmit.scala:904)
at org.apache.spark.deploy.SparkSubmit$.doRunMain$1(SparkSubmit.scala:198)
at org.apache.spark.deploy.SparkSubmit$.submit(SparkSubmit.scala:228)
at org.apache.spark.deploy.SparkSubmit$.main(SparkSubmit.scala:137)
Caused by: org.apache.spark.SparkException: Job aborted due to stage failure: Task 1 in stage 0.0 failed 4 times, most recent failure: Lost task 1.3 in stage 0.0 (TID 6, s05.ndtstu.local, executor 1): java.lang.AbstractMethodError: com.hortonworks.spark.sql.hive.llap.HiveWarehouseDataWriterFactory.createDataWriter(II)Lorg/apache/spark/sql/sources/v2/writer/DataWriter;
at org.apache.spark.sql.execution.datasources.v2.InternalRowDataWriterFactory.createDataWriter(WriteToDataSourceV2.scala:191)
at org.apache.spark.sql.execution.datasources.v2.DataWritingSparkTask$.run(WriteToDataSourceV2.scala:129)
at org.apache.spark.sql.execution.datasources.v2.WriteToDataSourceV2Exec$$anonfun$2.apply(WriteToDataSourceV2.scala:79)
at org.apache.spark.sql.execution.datasources.v2.WriteToDataSourceV2Exec$$anonfun$2.apply(WriteToDataSourceV2.scala:78)
at org.apache.spark.scheduler.ResultTask.runTask(ResultTask.scala:87)
at org.apache.spark.scheduler.Task.run(Task.scala:109)
at org.apache.spark.executor.Executor$TaskRunner.run(Executor.scala:345)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
Driver stacktrace:
at org.apache.spark.scheduler.DAGScheduler.org$apache$spark$scheduler$DAGScheduler$$failJobAndIndependentStages(DAGScheduler.scala:1651)
at org.apache.spark.scheduler.DAGScheduler$$anonfun$abortStage$1.apply(DAGScheduler.scala:1639)
at org.apache.spark.scheduler.DAGScheduler$$anonfun$abortStage$1.apply(DAGScheduler.scala:1638)
at scala.collection.mutable.ResizableArray$class.foreach(ResizableArray.scala:59)
at scala.collection.mutable.ArrayBuffer.foreach(ArrayBuffer.scala:48)
at org.apache.spark.scheduler.DAGScheduler.abortStage(DAGScheduler.scala:1638)
at org.apache.spark.scheduler.DAGScheduler$$anonfun$handleTaskSetFailed$1.apply(DAGScheduler.scala:831)
at scala.Option.foreach(Option.scala:257)
at org.apache.spark.scheduler.DAGScheduler.handleTaskSetFailed(DAGScheduler.scala:831)
at org.apache.spark.scheduler.DAGSchedulerEventProcessLoop.doOnReceive(DAGScheduler.scala:1872)
at org.apache.spark.scheduler.DAGSchedulerEventProcessLoop.onReceive(DAGScheduler.scala:1821)
at org.apache.spark.scheduler.DAGSchedulerEventProcessLoop.onReceive(DAGScheduler.scala:1810)
at org.apache.spark.util.EventLoop$$anon$1.run(EventLoop.scala:48)
at org.apache.spark.scheduler.DAGScheduler.runJob(DAGScheduler.scala:642)
at org.apache.spark.SparkContext.runJob(SparkContext.scala:2034)
at org.apache.spark.sql.execution.datasources.v2.WriteToDataSourceV2Exec.doExecute(WriteToDataSourceV2.scala:82)
... 25 more
Caused by: java.lang.AbstractMethodError: com.hortonworks.spark.sql.hive.llap.HiveWarehouseDataWriterFactory.createDataWriter(II)Lorg/apache/spark/sql/sources/v2/writer/DataWriter;
I can't not find any information regarding to this error
