Skip to main content
Niruu
Silver ⭐️⭐️
Jan 11, 2020 1:44 PM UTC
Solved
Changing IP and Hostname for Ambari Eco System
Hi All, I have a fresh Ambari eco system installed in my VMware Vsphere, assume its hostname is ambari01.example.com and IP Address is 192.168.1.10, I cloned it to ambari02 and changed IP 192.168.1.11. but unable to start services in ambari02.example, I think all eco system configuration files need to be modified, but not sure what all the files need to be modified. Might be some guys already tried this, can someone assist me. Thanks Niruu
Shelton
SheltonAnswer
Gold ⭐️⭐️⭐️
Jan 11, 2020 2:23 PM UTC
@Niruu
Here is a link changing ambari hostnames that should help you. I have used it successfully before but there are 2 hidden undocumented caveats, you should manually change the hostname in the ambari.properties there should be 2 or 3 properties to match the new VM hostname and also run some SQL like alter in the ambari, ranger, oozi, hive  databases you have to do this for all the fore mentioned components.
The contents of your host_names_changes.json should look like below make sure you have the correct cluster name, you will be prompted if you have already backed up your database etc in my case I usually  just accept , with a VM you can easily create another snapshot and you are good to go.
You must have completely stopped ambari and the agents
"cluster1" : {
"ambari01.example.com" : "ambari02.example.com"
The command should look like this
# ambari-server update-host-names  + host_names_changes.json
# ambari-server update-host-names host_names_changes.json
After completion, you should see successful
Note :
Remember to update the ambari-agent.ini to point to the new ambari02.example.com
If you use the above document you could stop on number 8 you don't need to format you Zk
For ambari database I am assuming you are using MariaDB or Mysql
mysql -u <ambari_user> -p<ambari_user_password>
GRANT ALL PRIVILEGES ON *.* TO 'ambari'@'<new_FQDN_new_VM>';
GRANT ALL PRIVILEGES ON *.* TO 'ambari'@'<new_FQDN_new_VM>' IDENTIFIED BY '<ambari_user_password>';
Hive to that for all the rest
mysql -u <hive_user> -p<hive_user_password>
GRANT ALL PRIVILEGES ON *.* TO 'hive'@'<new_FQDN_new_VM>';
GRANT ALL PRIVILEGES ON *.* TO 'hive'@'<new_FQDN_new_VM>' IDENTIFIED BY '<hive_user_password>';
Hope that helps
Happy hadooping
Shelton
SheltonAnswer
Gold ⭐️⭐️⭐️
@Niruu
"cluster1" : {
Note :
Hope that helps
Happy hadooping
Translate
Niruu
NiruuAuthor
Silver ⭐️⭐️
Jan 11, 2020 2:57 PM UTC
Shelton - Thank you very much
I will give a try and post the update.
Thanks
Niruu
Translate
Niruu
NiruuAuthor
Silver ⭐️⭐️
Jan 11, 2020 5:37 PM UTC
Hi Shelton,
Tons of thanks for you, you saved my whole weekend, Ambari is started as expected.. 🙂
Thanks
Niranjan
Translate
