Skip to main content
Alaaeldin
Bronze ⭐️⭐️⭐️
Apr 18, 2024 1:28 PM UTC
Solved
Complete example for using spark MLlib for twitter
I am new to this platform, and I need your help to get a complete case study (that includes spark MLlib and other tools to classify the data for example in Twitter) to apply in my environment.
jagadeesan
Platinum ⭐️
Apr 18, 2024 7:35 PM UTC
You can refer the Cloudera CDP documentation where it shows Spark MLlib using one of the Spark example applications. Also you can refer this article for Twitter Sentiment Analysis using Spark ML and Spark Streaming in Scala and it's Github source code here.
DianaTorres
Community Manager
Community Manager
Apr 18, 2024 7:12 PM UTC
@Alaaeldin Welcome to the Cloudera Community!
To help you get the best possible solution, I have tagged our Spark expert @jagadeesan  who may be able to assist you further.
Please keep us updated on your post, and we hope you find a satisfactory solution to your query.
Translate
Regards, Diana Torres, Senior Community Moderator
jagadeesan
Platinum ⭐️
Platinum ⭐️
Translate
DianaTorres
Community Manager
Community Manager
Apr 22, 2024 7:46 PM UTC
@Alaaeldin Has the reply helped resolve your issue? If so, please mark the appropriate reply as the solution, as it will make it easier for others to find the answer in the future.  Thanks.
Translate
