Skip to main content
Pr1
Silver ⭐️⭐️
Feb 9, 2021 2:46 PM UTC
Solved
Connect to kerberos authenticated schema registry using Python Library python-schema-registry-client
Hello ,
We have one use case where we need to connect to HDF schema registry using Python Library .
We have installed python-schema-registry-client  library.
But Schema registry URL is kerberos authenticated URL so couldn't connect with
below code
from schema_registry.client import SchemaRegistryClient, schema
client = SchemaRegistryClient(url="http://127.0.0.1:8081")
provided here https://marcosschroh.github.io/python-schema-registry-client/
Getting Authentication error 401.
Is there any extra arguments or methods to get connect to Schema registry using python library?
Thanks and Regards
TimothySpann
Platinum ⭐️⭐️⭐️
Feb 9, 2021 9:05 PM UTC
That Python is for the Confluent Schema Registry.
I was able to connect, but Confluent supports their own Avro schema format.
This was my example and it worked:
client = SchemaRegistryClient(url="http://myclouderasr.com:7788")
print( client.get_schema('weatherny') )
This library doesn't seem to support logins or security.
TimothySpann
Platinum ⭐️⭐️⭐️
Platinum ⭐️⭐️⭐️
Translate
Pr1
Pr1Author
Silver ⭐️⭐️
Feb 11, 2021 9:19 AM UTC
Thanks Spann for useful links and information about python-schema-registry-client library.
So now I can see  one of possible way to connect to kerberos Schema registry URL through python  is requests_kerberos library.
Thanks and Regards
Translate
