Skip to main content
phadkev
Silver ⭐️⭐️
Dec 18, 2024 9:53 AM UTC
Solved
CSVReader and CSVRecordSetWriter doesn't consider interger values present in double quotes as string
I am using CSVReader and CSVRecordSetWriter using the Infer schema setting. But when I have values such as "030", even though the all the values has double quotes enclosed. When I write the schema into avro.schema, I see it is considered as type 'int'. But I want to treat it as string. Because of this our output after the processor looks like 30 and the first 0 is omitted. I want to use Infer schema property only because, I want to read the csv files dynamically without hardcoding the schema and use that.
SAMSAL
SAMSALAnswer
Platinum ⭐️⭐️⭐️
Dec 20, 2024 1:49 PM UTC
Hi @phadkev ,
Im glad its working for you. Something I forgot to mention is that this will perform OK if your CSV dataset is small in size. Im not sure how inferring schema works but I imagine it does full scan on data to determine the appropriate type and if this the case this operation will be costly with large data. That is why its always recommend to know your schema and pass it when working with records.
Having said this , I was concerned about the performance of my suggestion above so I did more research and found that actually there is an easier way to convert everything to string in much faster way where you  don't need the extra processors. The suggestion is based on this post.
Basically, all you have to do in the CSVReader is to set the Access Schema Strategy to "Use String Fields From Header".
The CSVRecordWriter Access Schema Strategy should be set to "Inherit Record Schema"
That should do it. give it try and see how it goes.
Thanks
SAMSAL
Platinum ⭐️⭐️⭐️
Dec 18, 2024 3:44 PM UTC
Hi @phadkev ,
I'm not sure if there is a way around this without using Schema. You mentioned that you want to read the CSV files dynamically but does that mean you dont know what kind of CSV data you will get ? if so how are you parsing the data after conversion? what processor are you using the CSVReader & Write in ? maybe you can elaborate more on what you are trying to do with the data beginning to end to see if we can help in another way.
Translate
phadkev
phadkevAuthor
Silver ⭐️⭐️
Dec 19, 2024 5:16 AM UTC
Hi @SAMSAL ,
I'm using the CSV readers and writers in Query Record processor and CSVtoJSON Record Converter processor.
I am expecting around 10 types of CSV files(I mean to say, files with different columns). But this number might increase in the future upto 50. Even though I know what will these 50 files exactly contain, I'll still have to write all the 50 schemas in a schema registry. Which is complex to maintain and work with.
So I thought of this method in which I'll append all the values in a csv file with double quotes such that the reader and writer will consider it as a string. But it still continues to read it as an integer
Input File:
col1,col2,col3,col4,col5
999,C10,100,010,0
999,C06,10,010,0
This is what the CSV writer is giving:Screenshot 2024-12-19 104340.pngScreenshot 2024-12-19 104409.png
avro.schema
{"type":"record","name":"nifiRecord","namespace":"org.apache.nifi","fields":[{"name":"col1","type":["int","null"]},{"name":"col2","type":["int","null"]},{"name":"col3","type":["string","null"]},{"name":"col4","type":["int","null"]},{"name":"col5","type":["int","null"]}]}
Translate
SAMSAL
Platinum ⭐️⭐️⭐️
Dec 19, 2024 2:48 PM UTC
Hi @phadkev ,
Since you dont care if all the values come as string , then I would suggest doing the following:
1- Use the ExtractRecordSchema processor to generate the avro.schema attribute with the record schema as inferred by Nifi (Available 1.26+ version ) as follows:
The CSVReader for this processor will use infer schema strategy.
once you pass your CSV input through this processor you will have new flowfile attribute avro.schema with the following value
As Expected some of the values like name are assigned int type which we will take care of in the next step.
2- Use UpdateAttribute to replace any int type with string type inside the avro.schema attribute as follows:
The Expression Language used to re set the avro.schme attribute:
${avro.schema:replace("int","string")}
3- Use the QueryRecord with a different CSVReader from step 1  where this one uses the "use Schema Text Property" . Notice how by default the Shema Text property is set to the avro.schema attribute, which we generated from step 1&2:
Also make sure you set the same strategy for the CSVRecordWriter to ensure that the read and written CSV will be in  the desired format.
Hope that helps. If it does, please accept the solution.
Thanks
Translate
phadkev
phadkevAuthor
Silver ⭐️⭐️
Dec 20, 2024 6:14 AM UTC
Hi @SAMSAL ,
Thanks this did work.
Translate
SAMSAL
SAMSALAnswer
Platinum ⭐️⭐️⭐️
Hi @phadkev ,
Thanks
Translate
phadkev
phadkevAuthor
Silver ⭐️⭐️
Dec 20, 2024 3:26 PM UTC
@SAMSAL , This is indeed more efficient. Thanks for letting me know.
Translate
