Skip to main content
chiranjeevivenk
Gold ⭐️
Mar 14, 2019 5:38 AM UTC
Solved
def sample(a:Column,b:Column):Column={ var c:Column=null ;c=a*(1-b);c} error: overloaded method value + with alternatives cannot be applied to (org.apache.spark.sql.Column)
Hi! I'm trying to define a Scala function in Apache Spark that performs some column arithmetic, but I am running into a compilation error.
Here is my code:
Scala
def sample(a: Column, b: Column): Column = {
var c: Column = null
c = a * (1 - b)
c
When I try to use this, I get the following error message:
How can I fix this arithmetic expression so it works with Spark Column objects?
chiranjeevivenk
Gold ⭐️
May 15, 2019 9:54 PM UTC
c=a*(lit(1)-b)
1 reply
chiranjeevivenk
chiranjeevivenkAuthorAnswer
Gold ⭐️
c=a*(lit(1)-b)
Translate
