Skip to main content
Nur
Silver ⭐️
Feb 27, 2023 8:55 AM UTC
Solved
ERROR: Connecting to Kerberos Enabled Hive using Beeline Connection String
Hello,
I am unable to access Hive using Beeline connection string in the edge node. The JDBC String that I am using is as follows:
beeline -u "jdbc:hive2://Example.com:10000/default;principal=hive/Example.com@EXAMPLE.COM"
Error:
Unknown HS2 problem when communicating with Thrift server.
Error:jdbc:hive2://Example.com:10000/default;principal=hive/Example.com@EXAMPLE.COM: Invalid status 21 (state=08S01,code=0)
Help is required to fix this issue.
Thank you.
asish
asishAnswer
Gold ⭐️⭐️⭐️
Feb 27, 2023 11:33 AM UTC
I see that you are using CDP 7.1.7. Follow below steps if youare using autoTLS
1. Check TrustStore Password:
# cat /etc/hive/conf/ssl-client.xml | grep -i -A1 "ssl.client.truststore.password"
<name>ssl.client.truststore.password</name>
<value>truststore_password</value>
2. Below should be used for Kerberos + SSL
beeline -u "jdbc:hive2://xxxxxx10000/default;principal=hive/xxxxx@CREAL;ssl=true;sslTrustStore=/var/lib/cloudera-scm-agent/agent-cert/cm-auto-global_truststore.jks;trustStorePassword=trsutpwd"
asish
Gold ⭐️⭐️⭐️
Gold ⭐️⭐️⭐️
Feb 27, 2023 9:15 AM UTC
@Nur
1. are you using SSL ?
2. Provide
beeline -u "jdbc:hive2://Example.com:10000/default;principal=hive/Example.com@EXAMPLE.COM" --berbose=true
3. Hiveserver2 logs
Translate
Nur
NurAuthor
Silver ⭐️
Feb 27, 2023 11:24 AM UTC
1. Yes Iam using ssl
2. In below image have provided the output from the connection string
3. Have provided the SS for the log file in the below image.
Translate
asish
Gold ⭐️⭐️⭐️
asishAnswer
Gold ⭐️⭐️⭐️
Translate
VidyaSargur
Community Manager
Community Manager
Mar 3, 2023 5:46 AM UTC
@Nur, Have the replies helped resolve your issue? If so, please mark the appropriate reply as the solution, as it will make it easier for others to find the answer in the future.
Translate
Regards, Vidya Sargur Madabhushi| Senior Community Manager | Was your question answered? Make sure to mark the answer as the Best Answer. If you find a reply useful, say thanks by clicking on the thumbs up button.
bish765485
Silver ⭐️⭐️
Sep 26, 2024 11:45 AM UTC
Hey Guys,
I am also facing the same error while connecting via beeline with ssl and kerberos on the server:
root@ip-172-31-13-77:~# beeline -u jdbc:hive2://ec2-52-66-58-15.ap-south-1.compute.amazonaws.com:10000/default;principal=hive/ec2-52-66-58-15.ap-south-1.compute.amazonaws.com@AP-SOUTH-1.COMPUTE.AMAZONAWS.COM;saslqop=auth-conf
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/opt/cloudera/parcels/CDH-7.1.7-1.cdh7.1.7.p0.15945976/jars/log4j-slf4j-impl-2.13.3.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/opt/cloudera/parcels/CDH-7.1.7-1.cdh7.1.7.p0.15945976/jars/slf4j-log4j12-1.7.30.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
SLF4J: Actual binding is of type [org.apache.logging.slf4j.Log4jLoggerFactory]
WARNING: Use "yarn jar" to launch YARN applications.
Connecting to jdbc:hive2://ec2-52-66-58-15.ap-south-1.compute.amazonaws.com:10000/default
24/09/26 11:44:18 [main]: WARN jdbc.HiveConnection: Failed to connect to ec2-52-66-58-15.ap-south-1.compute.amazonaws.com:10000
Error: Could not open client transport with JDBC Uri: jdbc:hive2://ec2-52-66-58-15.ap-south-1.compute.amazonaws.com:10000/default: Invalid status 21 (state=08S01,code=0)
Please connect with someone expert on this  domain and get me correct .
Thanks in advance
Ankit Bishnoi
Translate
bish765485
Silver ⭐️⭐️
Sep 27, 2024 6:55 AM UTC
Any there from cloudera to help me on this issue.....
Translate
