Skip to main content
ansarifah
Gold ⭐️
Jul 21, 2016 2:01 AM UTC
Solved
HDFS Guide: How to Check Cluster Storage Capacity via Edge Node
Storage limit of NN and total storage capacity?
sunile_manjee
Gold ⭐️
Jul 21, 2016 2:06 AM UTC
Run sudo -u hdfs hdfs dfsadmin -report
This will give you full report on hdfs.
sunile_manjee
Gold ⭐️
Gold ⭐️
Translate
sunile_manjee
Gold ⭐️
Gold ⭐️
Jul 21, 2016 2:07 AM UTC
Report example
Configured Capacity: 7504658432 (6.99 GB)
Present Capacity: 527142912 (502.72 MB)
DFS Remaining: 36921344 (35.21 MB)
DFS Used: 490221568 (467.51 MB)
DFS Used%: 93.00%
Under replicated blocks: 128
Blocks with corrupt replicas: 0
Missing blocks: 0
Missing blocks (with replication factor 1): 0
Live datanodes (1):
Name: 192.168.114.48:50010 (host-192-168-114-48.td.local)
Hostname: host-192-168-114-48.td.local
Decommission Status : Normal
Non DFS Used: 6977515520 (6.50 GB)
DFS Used%: 6.53%
DFS Remaining%: 0.49%
Configured Cache Capacity: 0 (0 B)
Cache Used: 0 (0 B)
Cache Remaining: 0 (0 B)
Cache Used%: 100.00%
Cache Remaining%: 0.00%
Xceivers: 2
Translate
shivkumar82015
Gold ⭐️
Jul 22, 2016 2:05 PM UTC
you can check this $hadoop dfsadmin -report as below . You can check without "ROOT" user as well.
:~> hadoop dfsadmin -report
Use of this script to execute hdfs command is deprecated. Instead use the hdfs command for it.
Configured Capacity: 95930 (87.50 TB) Present Capacity: 95869819 (87.93 TB)
DFS Remaining: 37094235 (33.37 TB)
DFS Used: 587755833 (53.56 TB)
DFS Used%: 61.31%
Under replicated blocks: 0
Blocks with corrupt replicas: 5
Missing blocks: 0 -------------------------------------------------
report: Access denied for user "username".
Superuser privilege is required :~>
Translate
