Skip to main content
sampathkumar_ma
Gold ⭐️
Nov 6, 2019 10:58 AM UTC
Solved
Hive query on spark as execution engine in HDP 2.6.5
Hi,
We are getting the error while executing Hive query on spark as execution engine.
Hive version: 1.2.1, Spark version : 1.6
set hive.execution.engine=spark;
set spark.home=/usr/hdp/current/spark-client;
set spark.master=yarn-client;
set spark.eventLog.enabled=true;
set spark.executor.memory=512m;
set spark.executor.cores=2;
set spark.driver.extraClassPath=/usr/hdp/current/hive-client/lib/hive-exec.jar;
Query ID = svchdpir2d_20191106105445_a9ebc8a2-9c28-4a3d-ac5e-0a8609e56fd5
Total jobs = 1
Launching Job 1 out of 1
In order to change the average load for a reducer (in bytes):
set hive.exec.reducers.bytes.per.reducer=<number>
In order to limit the maximum number of reducers:
set hive.exec.reducers.max=<number>
In order to set a constant number of reducers:
set mapreduce.job.reduces=<number>
Starting Spark Job = c6cc1641-20ad-4073-ab62-4f621ae595c8
Status: SENT
Failed to execute spark task, with exception 'java.lang.IllegalStateException(RPC channel is closed.)'
FAILED: Execution Error, return code 1 from org.apache.hadoop.hive.ql.exec.spark.SparkTask
WARN: The method class org.apache.commons.logging.impl.SLF4JLogFactory#release() was invoked.
WARN: Please see http://www.slf4j.org/codes.html#release for an explanation.
Could you please help on this.
Thank you
ngarg
ngargAnswer
Gold ⭐️
Nov 9, 2019 6:23 AM UTC
@sampathkumar_ma - In HDP, Hive's execution engine only supports MapReduce & Tez. Running with Spark is not supported in HDP at this current moment in time.
sampathkumar_ma
Gold ⭐️
Nov 8, 2019 1:58 PM UTC
Can you please assist on this. Thanks
Translate
ngarg
Gold ⭐️
ngargAnswer
Gold ⭐️
Translate
