Skip to main content
vidanimegh
Gold ⭐️
July 1, 2021
Question
How to identify bottlenecks from Hive Query counters and Explain Plan
Hello All,
A Hive Query just ran for almost 7.5 Hours and I'm trying to understand what has caused such a significantly long runtime.
These are the query stats:
[2K[36;1m        VERTICES      MODE        STATUS  TOTAL  COMPLETED  RUNNING  PENDING  FAILED  KILLED
[22;0m[2K----------------------------------------------------------------------------------------------
[2KMap 1 .......... container SUCCEEDED 3348 3348 0 0 0 0
Map 4 .......... container SUCCEEDED 27 27 0 0 0 0
Reducer 2 ...... container SUCCEEDED 1009 1009 0 0 0 0
Reducer 3 ...... container SUCCEEDED 1 1 0 0 0 0
[2K[31;1mVERTICES: 04/04 [==========================>>] 100% ELAPSED TIME: 27285.00 s
INFO : Query Execution Summary
INFO : ----------------------------------------------------------------------------------------------
INFO : OPERATION DURATION
INFO : Compile Query 0.26s
INFO : Prepare Plan 0.05s
INFO : Get Query Coordinator (AM) 0.00s
INFO : Submit Plan 0.13s
INFO : Start DAG 0.03s
INFO : Run DAG 27270.01s
INFO :
INFO : Task Execution Summary
INFO : VERTICES DURATION(ms) CPU_TIME(ms) GC_TIME(ms) INPUT_RECORDS OUTPUT_RECORDS
INFO : Map 1 20831855.00 326,923,890 1,208,403 9,569,213,817 1,112,670,816,499
INFO : Map 4 38042.00 403,640 2,166 47,259,215 73,854,016
INFO : Reducer 2 6524435.00 108,305,790 1,367,042 9,617,725,549 1,009
INFO : Reducer 3 73228.00 2,860 0 1,009 0
INFO :
INFO : org.apache.tez.common.counters.DAGCounter:
INFO : NUM_SUCCEEDED_TASKS: 4385
INFO : TOTAL_LAUNCHED_TASKS: 4385
INFO : DATA_LOCAL_TASKS: 554
INFO : RACK_LOCAL_TASKS: 2821
INFO : AM_CPU_MILLISECONDS: 1643080
INFO : AM_GC_TIME_MILLIS: 6737
INFO : File System Counters:
INFO : FILE_BYTES_READ: 1860884020897
INFO : FILE_BYTES_WRITTEN: 3773542394532
INFO : HDFS_BYTES_READ: 2949584168417
INFO : HDFS_BYTES_WRITTEN: 74639411482
INFO : HDFS_READ_OPS: 8926
INFO : HDFS_WRITE_OPS: 3029
INFO : HDFS_OP_CREATE: 2019
INFO : HDFS_OP_GET_FILE_STATUS: 3029
INFO : HDFS_OP_OPEN: 5897
INFO : HDFS_OP_RENAME: 1010
INFO : org.apache.tez.common.counters.TaskCounter:
INFO : REDUCE_INPUT_GROUPS: 410577279
INFO : REDUCE_INPUT_RECORDS: 9617725549
INFO : COMBINE_INPUT_RECORDS: 0
INFO : SPILLED_RECORDS: 20722623211
INFO : NUM_SHUFFLED_INPUTS: 3406384
INFO : NUM_SKIPPED_INPUTS: 0
INFO : NUM_FAILED_SHUFFLE_INPUTS: 0
INFO : MERGED_MAP_OUTPUTS: 71643172699
INFO : GC_TIME_MILLIS: 2577611
INFO : TASK_DURATION_MILLIS: 406524896
INFO : CPU_MILLISECONDS: 435636180
INFO : PHYSICAL_MEMORY_BYTES: 75333726371840
INFO : VIRTUAL_MEMORY_BYTES: 88797821091840
INFO : COMMITTED_HEAP_BYTES: 75333726371840
INFO : INPUT_RECORDS_PROCESSED: 9570513520
INFO : INPUT_SPLIT_LENGTH_BYTES: 2949584055487
INFO : OUTPUT_RECORDS: 9617726558
INFO : OUTPUT_LARGE_RECORDS: 0
INFO : OUTPUT_BYTES: 2238503743864
INFO : OUTPUT_BYTES_WITH_OVERHEAD: 2139826941103
INFO : OUTPUT_BYTES_PHYSICAL: 1211054027209
INFO : ADDITIONAL_SPILLS_BYTES_WRITTEN: 425866143406
INFO : ADDITIONAL_SPILLS_BYTES_READ: 1747889484679
INFO : ADDITIONAL_SPILL_COUNT: 0
INFO : SHUFFLE_CHUNK_COUNT: 3375
INFO : SHUFFLE_BYTES: 1211054002993
INFO : SHUFFLE_BYTES_DECOMPRESSED: 2139826941103
INFO : SHUFFLE_BYTES_TO_MEM: 1003782114883
INFO : SHUFFLE_BYTES_TO_DISK: 0
INFO : SHUFFLE_BYTES_DISK_DIRECT: 207271888110
INFO : NUM_MEM_TO_DISK_MERGES: 180
INFO : NUM_DISK_TO_DISK_MERGES: 1116
INFO : SHUFFLE_PHASE_TIME: 14878024
INFO : MERGE_PHASE_TIME: 25783550
INFO : FIRST_EVENT_RECEIVED: 7091
INFO : LAST_EVENT_RECEIVED: 749095
INFO : DATA_BYTES_VIA_EVENT: 0
INFO : HIVE:
INFO : CREATED_FILES: 1010
INFO : DESERIALIZE_ERRORS: 0
INFO : RECORDS_IN_Map_1: 9569213817
INFO : RECORDS_IN_Map_4: 47259215
INFO : RECORDS_OUT_0: 1
INFO : RECORDS_OUT_1_upifrm2020.upi_ft_selected_py_510: 2196207622
INFO : RECORDS_OUT_INTERMEDIATE_Map_1: 1112670816499
INFO : RECORDS_OUT_INTERMEDIATE_Map_4: 73854016
INFO : RECORDS_OUT_INTERMEDIATE_Reducer_2: 1009
INFO : RECORDS_OUT_INTERMEDIATE_Reducer_3: 0
INFO : RECORDS_OUT_OPERATOR_FIL_32: 9570466334
INFO : RECORDS_OUT_OPERATOR_FIL_35: 47259215
INFO : RECORDS_OUT_OPERATOR_FS_10: 2196207622
INFO : RECORDS_OUT_OPERATOR_FS_20: 1
INFO : RECORDS_OUT_OPERATOR_GBY_16: 1009
INFO : RECORDS_OUT_OPERATOR_GBY_18: 1
INFO : RECORDS_OUT_OPERATOR_MAP_0: 0
INFO : RECORDS_OUT_OPERATOR_MERGEJOIN_31: 2196207622
INFO : RECORDS_OUT_OPERATOR_RS_17: 1009
INFO : RECORDS_OUT_OPERATOR_RS_34: 1112670816499
INFO : RECORDS_OUT_OPERATOR_RS_37: 73854016
INFO : RECORDS_OUT_OPERATOR_SEL_15: 2196207622
INFO : RECORDS_OUT_OPERATOR_SEL_33: 9570466334
INFO : RECORDS_OUT_OPERATOR_SEL_36: 47259215
INFO : RECORDS_OUT_OPERATOR_SEL_9: 2196207622
INFO : RECORDS_OUT_OPERATOR_TS_0: 9570466334
INFO : RECORDS_OUT_OPERATOR_TS_3: 47259215
INFO : TOTAL_TABLE_ROWS_WRITTEN: 2196207622
INFO : Shuffle Errors:
INFO : BAD_ID: 0
INFO : CONNECTION: 0
INFO : IO_ERROR: 0
INFO : WRONG_LENGTH: 0
INFO : WRONG_MAP: 0
INFO : WRONG_REDUCE: 0
INFO : Shuffle Errors_Reducer_2_INPUT_Map_1:
INFO : BAD_ID: 0
INFO : IO_ERROR: 0
INFO : WRONG_MAP: 0
INFO : Shuffle Errors_Reducer_2_INPUT_Map_4:
INFO : BAD_ID: 0
INFO : IO_ERROR: 0
INFO : WRONG_MAP: 0
INFO : TaskCounter_Map_1_INPUT_a:
INFO : INPUT_RECORDS_PROCESSED: 9570466334
INFO : INPUT_SPLIT_LENGTH_BYTES: 2949222655519
INFO : TaskCounter_Map_1_OUTPUT_Reducer_2:
INFO : ADDITIONAL_SPILLS_BYTES_READ: 0
INFO : ADDITIONAL_SPILLS_BYTES_WRITTEN: 0
INFO : OUTPUT_BYTES: 2237144940183
INFO : OUTPUT_BYTES_PHYSICAL: 1210237277829
INFO : OUTPUT_BYTES_WITH_OVERHEAD: 2138373445444
INFO : OUTPUT_RECORDS: 9570466334
INFO : SHUFFLE_CHUNK_COUNT: 3348
INFO : SPILLED_RECORDS: 9570466334
INFO : TaskCounter_Map_4_INPUT_b:
INFO : INPUT_RECORDS_PROCESSED: 46177
INFO : INPUT_SPLIT_LENGTH_BYTES: 361399968
INFO : TaskCounter_Map_4_OUTPUT_Reducer_2:
INFO : OUTPUT_BYTES: 1348619833
INFO : OUTPUT_BYTES_PHYSICAL: 808977386
INFO : OUTPUT_BYTES_WITH_OVERHEAD: 1443301721
INFO : OUTPUT_RECORDS: 47259215
INFO : SHUFFLE_CHUNK_COUNT: 27
INFO : SPILLED_RECORDS: 47259215
INFO : TaskCounter_Reducer_2_INPUT_Map_1:
INFO : ADDITIONAL_SPILLS_BYTES_READ: 1747171072110
INFO : ADDITIONAL_SPILLS_BYTES_WRITTEN: 425288767549
INFO : FIRST_EVENT_RECEIVED: 3494
INFO : LAST_EVENT_RECEIVED: 668391
INFO : MERGED_MAP_OUTPUTS: 71643145456
INFO : MERGE_PHASE_TIME: 25289522
INFO : NUM_SHUFFLED_INPUTS: 3378132
INFO : REDUCE_INPUT_GROUPS: 363318064
INFO : REDUCE_INPUT_RECORDS: 9570466334
INFO : SHUFFLE_BYTES: 1210237277829
INFO : SHUFFLE_BYTES_DECOMPRESSED: 2138373445444
INFO : SHUFFLE_BYTES_DISK_DIRECT: 207129855550
INFO : SHUFFLE_BYTES_TO_MEM: 1003107422279
INFO : SHUFFLE_PHASE_TIME: 14385309
INFO : SPILLED_RECORDS: 11057638447
INFO : TaskCounter_Reducer_2_INPUT_Map_4:
INFO : ADDITIONAL_SPILLS_BYTES_READ: 718412569
INFO : ADDITIONAL_SPILLS_BYTES_WRITTEN: 577375857
INFO : FIRST_EVENT_RECEIVED: 3584
INFO : LAST_EVENT_RECEIVED: 7551
INFO : MERGED_MAP_OUTPUTS: 27243
INFO : MERGE_PHASE_TIME: 494028
INFO : NUM_DISK_TO_DISK_MERGES: 0
INFO : NUM_MEM_TO_DISK_MERGES: 0
INFO : NUM_SHUFFLED_INPUTS: 27243
INFO : REDUCE_INPUT_GROUPS: 47259215
INFO : REDUCE_INPUT_RECORDS: 47259215
INFO : SHUFFLE_BYTES: 808977386
INFO : SHUFFLE_BYTES_DECOMPRESSED: 1443301721
INFO : SHUFFLE_BYTES_DISK_DIRECT: 141036712
INFO : SHUFFLE_BYTES_TO_MEM: 667940674
INFO : SHUFFLE_PHASE_TIME: 419560
INFO : TaskCounter_Reducer_2_OUTPUT_Reducer_3:
INFO : OUTPUT_BYTES: 10183848
INFO : OUTPUT_BYTES_PHYSICAL: 7771994
INFO : OUTPUT_BYTES_WITH_OVERHEAD: 10193938
INFO : OUTPUT_RECORDS: 1009
INFO : SPILLED_RECORDS: 0
INFO : TaskCounter_Reducer_3_INPUT_Reducer_2:
INFO : FIRST_EVENT_RECEIVED: 13
INFO : INPUT_RECORDS_PROCESSED: 1009
INFO : LAST_EVENT_RECEIVED: 73153
INFO : NUM_SHUFFLED_INPUTS: 1009
INFO : SHUFFLE_BYTES: 7747778
INFO : SHUFFLE_BYTES_DECOMPRESSED: 10193938
INFO : SHUFFLE_BYTES_DISK_DIRECT: 995848
INFO : SHUFFLE_BYTES_TO_MEM: 6751930
INFO : SHUFFLE_PHASE_TIME: 73155
INFO : TaskCounter_Reducer_3_OUTPUT_out_Reducer_3:
INFO : OUTPUT_RECORDS: 0
INFO : org.apache.hadoop.hive.ql.exec.tez.HiveInputCounters:
INFO : GROUPED_INPUT_SPLITS_Map_1: 3348
INFO : GROUPED_INPUT_SPLITS_Map_4: 27
INFO : INPUT_DIRECTORIES_Map_1: 96
INFO : INPUT_DIRECTORIES_Map_4: 1
INFO : INPUT_FILES_Map_1: 5843
INFO : INPUT_FILES_Map_4: 27
INFO : RAW_INPUT_SPLITS_Map_1: 5843
INFO : RAW_INPUT_SPLITS_Map_4: 27
This is the query:
create table mydb.mytbl
as select col1,col2,...col18
from mydb.tbl1 a
inner join mydb.tbl2 b on concat(trim(col1),trim(col2))=colb where date_partition_col between date_sub('2021-05-10',95) and '2021-05-10';
This is the explain plan:
| Explain |
| Plan optimized by CBO. |
| Vertex dependency in root stage |
| Map 1 <- Map 2 (BROADCAST_EDGE) |
| Stage-0 |
| Fetch Operator |
| limit:-1 |
| Stage-1 |
| Map 1 vectorized |
| File Output Operator [FS_30] |
| Select Operator [SEL_29] (rows=122690953 width=12844) |
| Output:["_col0","_col1","_col2","_col3","_col4","_col5","_col6","_col7","_col8","_col9","_col10","_col11","_col12","_col13","_col14","_col15","_col16","_col17"] |
| Map Join Operator [MAPJOIN_28] (rows=122690953 width=12844) |
| Conds:SEL_27._col18=RS_25._col0(Inner),Output:["_col0","_col1","_col2","_col3","_col4","_col5","_col6","_col7","_col8","_col9","_col10","_col11","_col12","_col13","_col14","_col15","_col16","_col17"] |
| <-Map 2 [BROADCAST_EDGE] vectorized |
| BROADCAST [RS_25] |
| PartitionCols:_col0 |
| Select Operator [SEL_24] (rows=47259215 width=110) |
| Output:["_col0"] |
| Filter Operator [FIL_23] (rows=47259215 width=110) |
| predicate:colb is not null |
| TableScan [TS_3] (rows=47259215 width=110) |
| mydb@tbl2,b, ACID table,Tbl:COMPLETE,Col:COMPLETE,Output:["colb"] |
| <-Select Operator [SEL_27] (rows=111537228 width=12844) |
| Output:["_col0","_col1","_col2","_col3","_col4","_col5","_col6","_col7","_col8","_col9","_col10","_col11","_col12","_col13","_col14","_col15","_col16","_col17","_col18"] |
| Filter Operator [FIL_26] (rows=111537228 width=12844) |
| predicate:(concat(trim(col1), trim(col2)) is not null and CAST( date_partition_col AS DATE) BETWEEN DATE'2021-02-04' AND DATE'2021-05-10') |
| TableScan [TS_0] (rows=1056668483 width=12844) |
| mydb@tbl1,a,Tbl:PARTIAL,Col:PARTIAL,Output:["col1","col2",...,"col18"] |
Can someone help me figure out the bottlenecks here?
Thanks,
Megh
asish
Gold ⭐️⭐️⭐️
Gold ⭐️⭐️⭐️
July 1, 2021
I see the two large tables are scanned and it is done at Map 1 phase  and scanned around 9,569,213,817 records.
predicate:(concat(trim(col1), trim(col2)) is not null and CAST( date_partition_col AS DATE) BETWEEN DATE'2021-02-04' AND DATE'2021-05-10') ==> scanning entire large table
Can you try below one:
as select col1,col2,...col18 where here date_partition_col between date_sub('2021-05-10',95) and '2021-05-10 from from mydb.tbl1 a
inner join mydb.tbl2 b on concat(trim(col1),trim(col2))=colb;
Translate
vidanimegh
Gold ⭐️
July 9, 2021
Hi @asish ,
Apologies for the late reply.
I tried the query you have suggested but still don't observe any difference in the runtime.
Thanks,
Megh
Translate
vidanimegh
Gold ⭐️
August 2, 2021
Hello @asish ,
Apologies for not replying earlier.
I recently thought that I'll compare a simple count(*) query performance on a single partition on my old cluster vs the current cluster and observe the difference I'm getting in the query counters.
What I discovered is that there is one GC_TIME_MILLIS counter which is significantly higher in the current cluster.
to give an example, this is the query I ran on both the clusters (Both clusters are having identical hardware and same amount of resources):
select count(*) from mydb.tbl1 where date_partition_col='2021-07-30';
Following is the trace from the old cluster:
Map 1 .......... container SUCCEEDED 64 64 0 0 0 0
Reducer 2 ...... container SUCCEEDED 1 1 0 0 0 0
VERTICES: 02/02 [==========================>>] 100% ELAPSED TIME: 79.65 s
INFO : Status: DAG finished successfully in 79.64 seconds
INFO :
INFO : Compile Query 0.23s
INFO : Prepare Plan 7.90s
INFO : Get Query Coordinator (AM) 0.21s
INFO : Submit Plan 0.24s
INFO : Start DAG 0.96s
INFO : Run DAG 79.64s
INFO :
INFO : Map 1 73845.00 1,642,830 10,289 127,396,873 95
INFO : Reducer 2 31853.00 4,120 71 64 0
INFO :
INFO : NUM_SUCCEEDED_TASKS: 65
INFO : TOTAL_LAUNCHED_TASKS: 65
INFO : DATA_LOCAL_TASKS: 7
INFO : RACK_LOCAL_TASKS: 57
INFO : AM_CPU_MILLISECONDS: 14500
INFO : AM_GC_TIME_MILLIS: 0
INFO : FILE_BYTES_READ: 300
INFO : FILE_BYTES_WRITTEN: 3840
INFO : HDFS_BYTES_READ: 39636387430
INFO : HDFS_BYTES_WRITTEN: 248
INFO : HDFS_READ_OPS: 130
INFO : HDFS_WRITE_OPS: 2
INFO : HDFS_OP_CREATE: 1
INFO : HDFS_OP_OPEN: 127
INFO : NUM_SHUFFLED_INPUTS: 64
INFO : GC_TIME_MILLIS: 10360
INFO : TASK_DURATION_MILLIS: 1505522
INFO : CPU_MILLISECONDS: 1646950
INFO : PHYSICAL_MEMORY_BYTES: 139586437120
INFO : VIRTUAL_MEMORY_BYTES: 607444127744
INFO : COMMITTED_HEAP_BYTES: 139586437120
INFO : INPUT_RECORDS_PROCESSED: 127429957
INFO : INPUT_SPLIT_LENGTH_BYTES: 39636387430
INFO : OUTPUT_RECORDS: 64
INFO : OUTPUT_BYTES: 384
INFO : OUTPUT_BYTES_WITH_OVERHEAD: 896
INFO : OUTPUT_BYTES_PHYSICAL: 3328
INFO : SHUFFLE_BYTES: 1792
INFO : SHUFFLE_BYTES_DECOMPRESSED: 896
INFO : SHUFFLE_BYTES_TO_MEM: 1652
INFO : SHUFFLE_BYTES_DISK_DIRECT: 140
INFO : SHUFFLE_PHASE_TIME: 30751
INFO : FIRST_EVENT_RECEIVED: 89
INFO : LAST_EVENT_RECEIVED: 30749
INFO : HIVE:
INFO : RECORDS_IN_Map_1: 127396873
INFO : RECORDS_OUT_INTERMEDIATE_Map_1: 95
INFO : RECORDS_OUT_INTERMEDIATE_Reducer_2: 0
INFO : RECORDS_OUT_OPERATOR_FS_13: 1
INFO : RECORDS_OUT_OPERATOR_GBY_10: 64
INFO : RECORDS_OUT_OPERATOR_GBY_12: 1
INFO : RECORDS_OUT_OPERATOR_RS_11: 95
INFO : RECORDS_OUT_OPERATOR_SEL_9: 127429893
INFO : RECORDS_OUT_OPERATOR_TS_0: 127429893
INFO : TaskCounter_Map_1_INPUT_urcs_transactions:
INFO : INPUT_RECORDS_PROCESSED: 127429893
INFO : INPUT_RECORDS_PROCESSED: 64
INFO : TaskCounter_Reducer_2_OUTPUT_out_Reducer_2:
INFO : GROUPED_INPUT_SPLITS_Map_1: 64
INFO : INPUT_DIRECTORIES_Map_1: 1
INFO : INPUT_FILES_Map_1: 127
INFO : RAW_INPUT_SPLITS_Map_1: 127
INFO : Completed executing command(queryId=hive_20210802162145_c6dc5748-ef38-42fb-becd-46dd33d2dd16); Time taken: 88.954 seconds
INFO : OK
| _c0 |
| 127429893 |
1 row selected (89.234 seconds)
Same query trace from the new cluster:
VERTICES: 02/02 [==========================>>] 100% ELAPSED TIME: 176.45 s
INFO : Status: DAG finished successfully in 176.42 seconds
INFO :
INFO : Compile Query 0.14s
INFO : Prepare Plan 0.04s
INFO : Submit Plan 4.79s
INFO : Start DAG 0.04s
INFO : Run DAG 176.42s
INFO :
INFO : Map 1 173773.00 9,458,900 151,977 127,398,948 95
INFO : Reducer 2 53863.00 2,490 0 64 0
INFO :
INFO : DATA_LOCAL_TASKS: 11
INFO : RACK_LOCAL_TASKS: 53
INFO : AM_CPU_MILLISECONDS: 22160
INFO : FILE_BYTES_READ: 480
INFO : HDFS_BYTES_WRITTEN: 109
INFO : HDFS_READ_OPS: 129
INFO : HDFS_OP_GET_FILE_STATUS: 2
INFO : GC_TIME_MILLIS: 151977
INFO : TASK_DURATION_MILLIS: 4806095
INFO : CPU_MILLISECONDS: 9461390
INFO : PHYSICAL_MEMORY_BYTES: 318765006848
INFO : VIRTUAL_MEMORY_BYTES: 607499304960
INFO : COMMITTED_HEAP_BYTES: 318765006848
INFO : SHUFFLE_BYTES_TO_MEM: 1568
INFO : SHUFFLE_BYTES_DISK_DIRECT: 224
INFO : SHUFFLE_PHASE_TIME: 54159
INFO : FIRST_EVENT_RECEIVED: 92
INFO : LAST_EVENT_RECEIVED: 54149
INFO : HIVE:
INFO : RECORDS_IN_Map_1: 127398948
| _c0 |
| 127429893 |
1 row selected (181.488 seconds)
The only significant difference I see between these two is for GC_TIME_MILLIS.
I tried to tune multiple Hive and YARN config settings related to Heap Memory and GC but there is no difference observed.
Any ideas?
Thanks,
Megh
Translate
