Skip to main content
Chetankumar
Silver ⭐️
Apr 19, 2021 8:12 AM UTC
Solved
How to move block from one mount point to other and remove old mount point
Hi,
I want to  remove some old disk and added new disk with new mount points. Now the new disk are part of  CDH. Now I want to  transfer the blocks from old disk /data01 to new disk /data05 and then remove /data01 after move of all blocks.
Is there a way to do this ?
can I take datanode services down and then manually copy? will Cloudera able to find the new blocks on /data05 (new disk) ?
kingpin
kingpinAnswer
Gold ⭐️
Apr 19, 2021 5:17 PM UTC
Hi @Chetankumar
You can perform disk hot swap of DN.
https://docs.cloudera.com/documentation/enterprise/6/6.3/topics/admin_dn_swap.html
If the Replication factor is set to 3 for all the files then taking down one disk shouldn't be a problem as Namenode will auto-replicate the under-replicated blocks. As part of small test first stop the datanode and wait for sometime (While NN copies the blocks to other available datanodes).
Run fsck to confirm if HDFS file system is healthy. When it is healthy, you can easily play around with that stopped datanode. Idea is to ensure the replication factor to 3 so that you dont incur any dataloss.
if the Replication factor is set to 1 for some files and if those blocks are hosted on that /data01 disk. Then it could be a potential loss. As long as you have RF=3 you would be good.
Does that answer your questions ? Let us know
Regards,
kingpin
Gold ⭐️
kingpinAnswer
Gold ⭐️
Hi @Chetankumar
Regards,
Translate
Chetankumar
Silver ⭐️
Apr 20, 2021 1:26 PM UTC
Hi @kingpin
Thanks for  your reply. Yes this solution worked and now we are able to remove the old disk and after rebalance new disks are in use. We will continue to remove the disk from each node after the rebalance complete after each attempt.
Translate
