Skip to main content
vimal3ar_be
Silver ⭐️⭐️
Jan 11, 2019 10:36 PM UTC
Solved
How to process provenance repository (Provenance data @ MINIFI ) using SITE TO SITE PROVENANCE Data using APACHE NIFI
@Timothy Spann
In Apache NIFI http://localhost:8080/nifi
I configured NIFI to Ingest Minifi logs to Nifi as below:
  • a) Reading Minifi Logs using "Tail File" process and then the flow file is forwarded to NIFI http://localhost:8080/nifi using Remote Process Group.
  • b) After receiving flowfile data at Nifi content of log file is read and written in CSV format in output file using put file.
Now using SITE TO SITE TO PROVENANCE REPORT I can send NIFI's Provenance data to another instance of NIFI. It is working fine. Now need to know how to send MINIFI's Provenance data to another instance of NIFI. Is there a way to read Provenance data at MINIFI end.
Note: There is Provenance Repository folder in both NIFI and MINIFI installation directory.
Please help
Thanks
TimothySpann
Platinum ⭐️⭐️⭐️
Jan 11, 2019 10:50 PM UTC
Whenever you send something from minifi to nifi over Site to Site, as soon as it arrives in NiFi it has all the provenance data.
TimothySpann
Platinum ⭐️⭐️⭐️
Platinum ⭐️⭐️⭐️
Translate
vimal3ar_be
Silver ⭐️⭐️
Jan 12, 2019 5:09 PM UTC
Thank You
Translate
vimal3ar_be
Silver ⭐️⭐️
Jan 12, 2019 5:13 PM UTC
Tomothy Spann
Thank you for timely help.
Translate
