Skip to main content
PradNiFi1236
Gold ⭐️
Mar 11, 2024 7:57 PM UTC
Solved
how to replace first element of an array using jolt
Hi All,
I would like to replace first element of an array value  i.e would like to replace with first net val with nifi attribute
input
"iH": [
"DN": "711449",
"iLineList": [
"DNnumber": "711449",
"DNLineNumber": 2
"DNNumber": "711449",
"DNLineNumber": 3
"netval": "22.09"
"DN": "711450",
"iLineList": [
"DNnumber": "711450",
"DNLineNumber": 2
"DNNumber": "711450",
"DNLineNumber": 3
"netval": "11.09"
defined SPEC like :
"operation": "shift",
"spec": {
"0": {
"netVal": "iH[&1].netVal[0]",
"*": "iH[&1].&"
"*": "&1"
"operation": "modify-overwrite-beta",
"spec": {
// "invoiceHeader": {
"0": {
"netVal": "${netVal}"
Expected output:
"iH" : [ {
"DN" : "711449",
"iLineList" : [ {
"DNnumber" : "711449",
"DNLineNumber" : 2
"DNNumber" : "711449",
"DNLineNumber" : 3
"netval" : "${netval}"
"DN" : "711450",
"iLineList" : [ {
"DNnumber" : "711450",
"DNLineNumber" : 2
"DNNumber" : "711450",
"DNLineNumber" : 3
"netval" : "11.09"
SAMSAL
SAMSALAnswer
Platinum ⭐️⭐️⭐️
Mar 12, 2024 2:33 AM UTC
Hi,
This is interesting . It looks trivial initially but its not that simple 🙂 It took me trial and error to get it to work using modify-overwrite-beta because the syntax is different from the shift spec where you reference array element at n index as "n" while in modify-overwrite-beta its "[0]" ! not sure why the difference.  So this should work:
"spec": {
"iH": {
"[0]": {
"netval": "${netval}"
You can also do it using shift as follows:
"spec": {
"0": {
"netval": {
"#${netval}": "&3[&2].&1"
"*": "&2[&1].&"
"*": "&1[&]"
If that helps please accept solution.
Thanks
SAMSAL
SAMSALAnswer
Platinum ⭐️⭐️⭐️
Hi,
"spec": {
"iH": {
"[0]": {
"spec": {
"0": {
"netval": {
"*": "&2[&1].&"
"*": "&1[&]"
Thanks
Translate
PradNiFi1236
Gold ⭐️
Mar 12, 2024 5:32 PM UTC
Thanks a Lot the JOLT Master @SAMSAL , Modify-overwrite beta -logic worked perfectly.
but for Shift logic jolt demo throwing an execption Invalid reference key=#${netval} either blank or doesn't start with correct character=$
Translate
PradNiFi1236
Gold ⭐️
Mar 13, 2024 6:54 PM UTC
@SAMSAL , After i added escaping to $ with double slash it got worked in shift too.
"#\\${netval}": "&3[&2].&1"
thanks a lot again
Translate
