Skip to main content
luckes
Silver ⭐️⭐️⭐️
Jun 9, 2022 2:55 AM UTC
Solved
impala jdbc doesn't work for preparestatement when using upsert
I am using the latest version of impala JDBC Driver 2.6.27.1032, when my sql is  "upsert into my.testtable(id,name,insert_time) values(?,?,?)" and using preparestatement, then the column "insert_time" will be replaced to "upsert_time", so my sql be changed to "upsert into my.testtable(id,name,upsert_time) values(?,?,?)"  and i get a error "errorMessage:AnalysisException: Unknown column 'UPSERTby' in column permutation",。
How can I solve this problem?
please!
ShankerSharma
Gold ⭐️
Jun 10, 2022 4:56 AM UTC
Hello Team,
We have tested the java code internally and it worked fine for us.
ClouderaJDBC version:- 2.6.27.1032
Java code:-
import java.sql.*;
import java.math.*;
public class test{
public static void main(String args[]){
try{
Class.forName("com.cloudera.impala.jdbc41.Driver");
Connection con=DriverManager.getConnection("jdbc:impala://<<hostname>>
:21050;UseNativeQuery=1");
String sql = "upsert into user_info(id, name, address, email, insert_time) values (?,?,?,?,?)";
PreparedStatement statement = con.prepareStatement(sql);
statement.setInt(1, 102);
statement.setString(2, "Peter");
statement.setString(3, "New York");
statement.setString(4, "John@xyz.com");
statement.setTimestamp(5, java.sql.Timestamp.valueOf(java.time.LocalDateTime.now()));
statement.addBatch();
statement.executeBatch();
statement.close();
con.close();
catch(Exception e){
System.out.println(e);
Please let us know if it helps.
luckes
luckesAuthor
Silver ⭐️⭐️⭐️
Jun 9, 2022 3:31 AM UTC
impala jdbc driver can using method
replaceFirst("insert","upsert")
to replace the first "insert" keyword?
Translate
ShankerSharma
Gold ⭐️
Gold ⭐️
Jun 9, 2022 7:29 AM UTC
Please elaborate a little more on the issue:-
Also please share the steps you are performing and share the table DDL for the same.
Translate
luckes
luckesAuthor
Silver ⭐️⭐️⭐️
Jun 9, 2022 9:53 AM UTC
the table DDL is:
create table mid.user_info(id int,name string,address string,email string,insert_time timestamp,primary key(id)) partition by hash(id) partitions 6 stored as kudu;
public class test {
public static void main(String[] args) throws ClassNotFoundException, SQLException {
Class.forName("com.cloudera.impala.jdbc.Driver");
Connection connection = DriverManager.getConnection("jdbc:impala://impala.db.com:8006/default;auth=noSasl", "impala", "6712dxgvwe");
String sql = "upsert into mid.user_info(id, name, address, email, insert_time) values(?,?,?,?,?)";
PreparedStatement statement = connection.prepareStatement(sql);
statement.setInt(1, 100);
statement.setString(2, "John");
statement.setString(4, "John@iis.com");
statement.setTimestamp(5, Timestamp.valueOf(LocalDateTime.now()));
statement.close();
connection.close();
 when I execute it, I got a error as:
Exception in thread "main" java.sql.SQLException: [Cloudera][ImpalaJDBCDriver](500051) ERROR processing query/statement. Error Code: 0, SQL state: TStatus(statusCode:ERROR_STATUS, sqlState:HY000, errorMessage:AnalysisException: Unknown column 'UPSERT_time' in column permutation
), Query: UPSERT INTO `mid`.`user_info`(`id`, `name`, `address`, `email`, `UPSERT_time`) VALUES (100, CAST('John' AS CHAR(4)), CAST('New York' AS CHAR(8)), CAST('John@iis.com' AS CHAR(12)), '2022-06-09 17:52:10.3808341').
at com.cloudera.impala.hivecommon.api.HS2Client.executeStatementInternal(Unknown Source)
at com.cloudera.impala.hivecommon.api.HS2Client.executeStatement(Unknown Source)
at com.cloudera.impala.hivecommon.dataengine.HiveJDBCNativeQueryExecutor.executeHelper(Unknown Source)
at com.cloudera.impala.hivecommon.dataengine.HiveJDBCNativeQueryExecutor.execute(Unknown Source)
at com.cloudera.impala.jdbc.common.SPreparedStatement.executePreparedAnyBatch(Unknown Source)
at com.cloudera.impala.jdbc.common.SPreparedStatement.executeBatch(Unknown Source)
Caused by: com.cloudera.impala.support.exceptions.GeneralException: [Cloudera][ImpalaJDBCDriver](500051) ERROR processing query/statement. Error Code: 0, SQL state: TStatus(statusCode:ERROR_STATUS, sqlState:HY000, errorMessage:AnalysisException: Unknown column 'UPSERT_time' in column permutation
... 6 more
Translate
mszurap
Platinum ⭐️
Platinum ⭐️
Jun 9, 2022 10:25 AM UTC
Hi @luckes , thanks for reporting this. Based on your descriptinon yes, it seems the upsert is replaced everywhere to insert by the driver. Please open a support case through MyCloudera support portal to have this routed to the proper team for enhancement.
Other ideas:
- have you checked if this behavior can be observed with the latest JDBC driver version too?
- please check if the "UseNativeQuery=1" helps in the JDBC connection string
- does it work if you avoid the "insert" from the column ("insert_time") names, so for example with a "modification_time" column name?
Thank you
 Miklos Szurap, Customer Operations Engineer, Cloudera
Translate
ShankerSharma
Gold ⭐️
Gold ⭐️
Hello Team,
Java code:-
import java.sql.*;
import java.math.*;
public class test{
try{
statement.close();
con.close();
catch(Exception e){
Translate
luckes
luckesAuthor
Silver ⭐️⭐️⭐️
Jun 10, 2022 6:02 AM UTC
It works by adding the parameter “UseNativeQuery=1” to the URL!
thanks a lot!
Translate
