Skip to main content
Amandi
Silver ⭐️⭐️⭐️
Oct 3, 2024 10:09 AM UTC
Question
ImportTsv Failing with Exit Code 1 and SLF4J Logger Issue in HBase MapReduce Job
Dear Cloudera Support Team,
I am experiencing an issue when running the ImportTsv command in HBase using the following command:
hbase org.apache.hadoop.hbase.mapreduce.ImportTsv -Dimporttsv.separator='\t' -Dimporttsv.columns='HBASE_ROW_KEY,cf:gender,cf:age,cf:income,cf:exp' Customers /hbase/data.txt
The job is failing with the following error message:
2024-10-03T15:00:41,530 INFO [main] mapreduce.Job: Running job: job_1727859616916_0004
2024-10-03T15:00:50,594 INFO [main] mapreduce.Job: Job job_1727859616916_0004 running in uber mode : false
2024-10-03T15:00:50,597 INFO [main] mapreduce.Job: map 0% reduce 0%
2024-10-03T15:00:50,616 INFO [main] mapreduce.Job: 9616916_0004_02_000001
Exit code: 1
[2024-10-03 15:00:49.597]Container exited with a non-zero exit code 1. Error file: prelaunch.err.
Last 4096 bytes of prelaunch.err :
Last 4096 bytes of stderr :
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
For more detailed output, I have checked the logs on the application tracking page as well:
http://dc1-apache-hbase.mobitel.lk:8088/cluster/app/application_1727859616916_0004
here is the above mentioned (application_1727859616916_0004) result.
User:Name:Application Type:Application Tags:Application Priority:YarnApplicationState:Queue:FinalStatus Reported by AM:Started:Launched:Finished:Elapsed:Tracking URL:Log Aggregation Status:Application Timeout (Remaining Time):Diagnostics:Unmanaged Application:Application Node Label expression:AM container Node Label expression:
super
importtsv_Customers
MAPREDUCE
0 (Higher Integer value indicates higher priority)
FAILED
default
FAILED
Thu Oct 03 15:00:41 +0530 2024
Thu Oct 03 15:00:42 +0530 2024
Thu Oct 03 15:00:49 +0530 2024
8sec
History
DISABLED
Unlimited
Application application_1727859616916_0004 failed 2 times due to AM Container for appattempt_1727859616916_0004_000002 exited with exitCode: 1
Failing this attempt.Diagnostics: [2024-10-03 15:00:49.594]Exception from container-launch.
Container id: container_1727859616916_0004_02_000001
Exit code: 1
[2024-10-03 15:00:49.598]Container exited with a non-zero exit code 1. Error file: prelaunch.err.
For more detailed output, check the application tracking page: http://dc1-apache-hbase.mobitel.lk:8088/cluster/app/application_1727859616916_0004 Then click on links to logs of each attempt.
. Failing the application.
false
<Not set>
<DEFAULT_PARTITION>
Could you please assist in resolving this issue?
Thank you for your support.
1 reply
DianaTorres
Community Manager
Community Manager
Oct 3, 2024 11:36 PM UTC
Hi! @shubham_sharma @aquilodran @Anandh_S Do you have any insights here? Thanks
Translate
Regards, Diana Torres, Senior Community Moderator
