Skip to main content
rsurti
Gold ⭐️
Nov 11, 2024 7:15 AM UTC
Solved
Insert into table test values('a', 'b'); not working on Hive with tez execution engine
Hi,
         I am trying to run simple query on Hive with execution engine as Tez,
Here is the query
there are only two columns in table and both are string columns.
If i insert into int column  then it works fine.
also if i insert through load data command, this also works fine with string command.
Below is the error that i am getting in yarn logs:
ERROR : Status: Failed
ERROR : Vertex failed, vertexName=Map 1, vertexId=vertex_1731065811939_0001_1_00, diagnostics=[Vertex vertex_1731065811939_0001_1_00 [Map 1] killed/failed due to:ROOT_INPUT_INIT_FAILURE, Vertex Input: _dummy_table initializer failed, vertex=vertex_1731065811939_0001_1_00 [Map 1], java.lang.RuntimeException: Failed to load plan: hdfs://localhost:9000/tmp/hive/hadoopuser/a86dedab-ce0f-4f06-8056-c37aef3cca55/hive_2024-11-11_12-26-32_369_2945486912443049901-2/hadoopuser/_tez_scratch_dir/8d991848-0c76-4ffa-a82e-76f0ca5140e5/map.xml
at org.apache.hadoop.hive.ql.exec.Utilities.getBaseWork(Utilities.java:525)
at org.apache.hadoop.hive.ql.exec.Utilities.getMapWork(Utilities.java:369)
at org.apache.hadoop.hive.ql.io.HiveInputFormat.init(HiveInputFormat.java:480)
at org.apache.hadoop.hive.ql.io.CombineHiveInputFormat.getSplits(CombineHiveInputFormat.java:508)
at org.apache.tez.mapreduce.hadoop.MRInputHelpers.generateOldSplits(MRInputHelpers.java:472)
at org.apache.tez.mapreduce.hadoop.MRInputHelpers.generateInputSplitsToMem(MRInputHelpers.java:321)
at org.apache.tez.mapreduce.common.MRInputAMSplitGenerator.initialize(MRInputAMSplitGenerator.java:121)
at org.apache.tez.dag.app.dag.RootInputInitializerManager$InputInitializerCallable$1.run(RootInputInitializerManager.java:281)
at org.apache.tez.dag.app.dag.RootInputInitializerManager$InputInitializerCallable$1.run(RootInputInitializerManager.java:272)
at javax.security.auth.Subject.doAs(Subject.java:422)
at org.apache.hadoop.security.UserGroupInformation.doAs(UserGroupInformation.java:1899)
at org.apache.tez.dag.app.dag.RootInputInitializerManager$InputInitializerCallable.call(RootInputInitializerManager.java:272)
at org.apache.tez.dag.app.dag.RootInputInitializerManager$InputInitializerCallable.call(RootInputInitializerManager.java:256)
at com.google.common.util.concurrent.TrustedListenableFutureTask$TrustedFutureInterruptibleTask.runInterruptibly(TrustedListenableFutureTask.java:131)
at com.google.common.util.concurrent.InterruptibleTask.run(InterruptibleTask.java:75)
at com.google.common.util.concurrent.TrustedListenableFutureTask.run(TrustedListenableFutureTask.java:82)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:750)
Caused by: org.apache.hive.com.esotericsoftware.kryo.KryoException: Encountered unregistered class ID: 112
Serialization trace:
conf (org.apache.hadoop.hive.ql.exec.TableScanOperator)
aliasToWork (org.apache.hadoop.hive.ql.plan.MapWork)
at org.apache.hive.com.esotericsoftware.kryo.util.DefaultClassResolver.readClass(DefaultClassResolver.java:159)
at org.apache.hive.com.esotericsoftware.kryo.Kryo.readClass(Kryo.java:758)
at org.apache.hadoop.hive.ql.exec.SerializationUtilities$KryoWithHooks.readClass(SerializationUtilities.java:188)
at org.apache.hive.com.esotericsoftware.kryo.serializers.ReflectField.read(ReflectField.java:117)
at org.apache.hive.com.esotericsoftware.kryo.serializers.FieldSerializer.read(FieldSerializer.java:129)
at org.apache.hive.com.esotericsoftware.kryo.Kryo.readClassAndObject(Kryo.java:877)
at org.apache.hadoop.hive.ql.exec.SerializationUtilities$KryoWithHooks.readClassAndObject(SerializationUtilities.java:183)
at org.apache.hive.com.esotericsoftware.kryo.serializers.MapSerializer.read(MapSerializer.java:235)
at org.apache.hive.com.esotericsoftware.kryo.serializers.MapSerializer.read(MapSerializer.java:42)
at org.apache.hive.com.esotericsoftware.kryo.Kryo.readObject(Kryo.java:796)
at org.apache.hadoop.hive.ql.exec.SerializationUtilities$KryoWithHooks.readObject(SerializationUtilities.java:221)
at org.apache.hive.com.esotericsoftware.kryo.serializers.ReflectField.read(ReflectField.java:124)
at org.apache.hive.com.esotericsoftware.kryo.Kryo.readObject(Kryo.java:774)
at org.apache.hadoop.hive.ql.exec.SerializationUtilities$KryoWithHooks.readObject(SerializationUtilities.java:213)
at org.apache.hadoop.hive.ql.exec.SerializationUtilities.deserializeObjectByKryo(SerializationUtilities.java:838)
at org.apache.hadoop.hive.ql.exec.SerializationUtilities.deserializePlan(SerializationUtilities.java:745)
at org.apache.hadoop.hive.ql.exec.Utilities.getBaseWork(Utilities.java:489)
... 19 more
Can anyone guide here?
ggangadharan
Gold ⭐️
Nov 15, 2024 2:38 PM UTC
  • The below error usually occurs when there is a mismatch between the versions of Tez and Hive. Validate the compatibility.
... 19 more
  • Additionally, it is important to validate if any auxiliary jars are being used and ensure that these jars do not conflict with the jars in the Hive classpath. if two versions of same jars are present in the classapth , which also creates a problem in the serialization.
1 reply
ggangadharan
Gold ⭐️
Gold ⭐️
... 19 more
Translate
