Skip to main content
imule
Silver ⭐️⭐️
Aug 30, 2023 12:25 PM UTC
Solved
Issue running spark jobs with Airflow
Hi everyone,
So I've inherited a kerberized Cloudera cluster and I'm learning as I go. Right now I'm trying to get Airflow to work with our Spark jobs but without success. As I understand Airflow was installed by our OS team only after the cluster was configured by Cloudera. It runs on our edge node from where we run our jobs.
Basically I'm using bash operators for my test DAG with the following tasks:
Task 1:
Kinit the user that is running the script:
"echo 'password' | kinit user@domain"
Task 2:
Download some files from some location.
Task 3:
spark-submit /path/to/script.py
Task 1 and 2 work fine, but task 3 fails with the following:
py4j.protocol.Py4JJavaError: An error occurred while calling o32.csv.
: org.apache.hadoop.security.AccessControlException: org.apache.hadoop.security.AccessControlException: SIMPLE authentication is not enabled.  Available:[TOKEN, KERBEROS]
I am a bit confused by this as I am am authenticating the user as a first step. This exact workflow executes just fine when I run it manually in the CL.
Has anyone dealt with a similar issue? Any input would be appreciated as we need to transition to using Airflow.
Many thanks,
Mario
RangaReddy
Gold ⭐️
Oct 3, 2023 5:58 AM UTC
There are two solutions you can try.
1. Create one more shell operator and perform kinit and after that submit your spark
2. Pass the keytab and principal to the spark-submit
RangaReddy
Gold ⭐️
Gold ⭐️
Aug 31, 2023 8:20 AM UTC
Hi @imule
In step3, could you please pass --keytab <key_tab_path> --principal <principal_name> to the spark-submit command.
Note: In CDP, Airflow integration is not yet we are supported.
Translate
imule
imuleAuthor
Silver ⭐️⭐️
Aug 31, 2023 2:16 PM UTC
Hi @RangaReddy ,
Is there a way to generate the file myself or do I need to contact our Active Directory administrators for that?
Thank you
Translate
RangaReddy
Gold ⭐️
Gold ⭐️
Sep 4, 2023 4:53 AM UTC
Hi @imule
You can follow the following steps to generate the keytab and if you don't have permission, please check with your admin team.
https://docs.cloudera.com/data-hub/cloud/access-clusters/topics/dh-retrieving-keytabs.html
Translate
VidyaSargur
Community Manager
Community Manager
Sep 20, 2023 2:02 PM UTC
@imule, Has the reply helped resolve your issue? If so, please mark the appropriate reply as the solution, as it will make it easier for others to find the answer in the future.
Translate
Regards, Vidya Sargur Madabhushi| Senior Community Manager | Was your question answered? Make sure to mark the answer as the Best Answer. If you find a reply useful, say thanks by clicking on the thumbs up button.
imule
imuleAuthor
Silver ⭐️⭐️
Oct 2, 2023 1:29 PM UTC
Hi again @RangaReddy ,
I'm sorry for the huge delay in reply, unfortunately this triggered a lengthy discussion between us and the AD team.
In the end we managed to get our hands on a keytab file, and we confirmed it works fine by manually submitting the below command:
kinit -k -t /path/to/keytab/file.keytab username
Unfortunately when we attempt to pass this with a bash operator from an Airflow DAG we get the same error:
Thank you,
Mario
Translate
RangaReddy
Gold ⭐️
Gold ⭐️
Translate
