Issue with HBase HMaster Disappearing When Starting HBase Shell in Pseudo-Distributed Mode
Dear Cloudera Community,
I am currently testing HBase for bulk loading purposes, and for this, we use the pseudo-distributed mode (single-host standalone) as our configuration. After completing all the configurations, I executed the jps command, which displayed all the necessary processes for testing.
[super@dc1-apache-hbase bin]$ jps
1119857 Jps
1118448 NodeManager
1119235 HQuorumPeer
1117730 NameNode
1117863 DataNode
1119627 HRegionServer
1118125 SecondaryNameNode
1119405 HMaster
1118332 ResourceManager
Additionally, I did not use Zookeeper manually for the process; instead, I used export HBASE_MANAGES_ZK=true.
However, once I enter the HBase shell, the HMaster process disappears, and I encounter the following error message:
"ERROR: KeeperErrorCode = NoNode for /hbase/master"
[super@dc1-apache-hbase conf]$ jps
1122225 Jps
1118448 NodeManager
1121283 HQuorumPeer
1122019 JarBootstrapMain
1117730 NameNode
1117863 DataNode
1121675 HRegionServer
I have attached all the configuration files and version details that I used for this setup. Could you please assist me in resolving this issue?
Hadoop Version: 3.3.6
Hbase Version: 2.5.10
Java Version:
openjdk version "1.8.0_422"
OpenJDK Runtime Environment (build 1.8.0_422-b05)
OpenJDK 64-Bit Server VM (build 25.422-b05, mixed mode)
hbase-site.xml:
<property>
<name>hbase.cluster.distributed</name>
<value>true</value>
</property>
<property>
<name>hbase.zookeeper.property.dataDir</name>
<value>/home/super/zookeeper</value>
</property>
<property>
<name>hbase.zookeeper.quorum</name>
<value>localhost</value>
</property>
<property>
<name>hbase.rootdir</name>
<value>hdfs://localhost:8030/hbase</value>
</property>
<property>
<name>hbase.zookeeper.property.clientPort</name>
<value>2181</value>
</property>
hbase-env.sh
# The java implementation to use. Java 1.8+ required.
# export JAVA_HOME=/usr/java/jdk1.8.0/
export JAVA_HOME=/usr/local/java-1.8.0-openjdk-1.8.0.422.b05-2.el9.x86_64
# Extra Java CLASSPATH elements. Optional.
# export HBASE_CLASSPATH=
export HBASE_CLASSPATH=$HADOOP_CONF_DIR:$HBASE_CLASSPATH
Thank you for your support.
