Issue with String to Timestamp Conversion in Hive and Spark Resulting in Unexpected Hour Changes
We are experiencing an issue with converting data from string to timestamp in Hive, where the timestamps undergo unexpected hour changes during conversion and processing.
We would like to verify if this could be a bug in the tool or if there are additional configurations required.
Process and Steps to Reproduce the Issue: Loading Data into HDFS:
1. We use the hdfs put command to load a positional file into HDFS and store it in a directory accessible via an external table ex_sa_beneficios_mantidos where the data is in string format.
2. We create an external table in Hive to access the data as strings.
3. Converting String to Timestamp and Writing to ORC Table: When converting the string to timestamp, we notice an alteration in the hour of the dt_afast_trabalho field.
4. Verifying the Conversion and Data Reading: When reading the data from the ORC table, the hours in the dt_afast_trabalho field were different from expected.
5. Counting Timestamps by Hour: We performed a count by hour of the timestamps to verify the changes. Spark Configuration in Zeppelin: When initializing Hive in Zeppelin, we used the following parameters:
Expected Behavior: We expect the hour values of the dt_afast_trabalho field to remain consistent throughout the conversion and processing stages, respecting the America/Sao_Paulo timezone.
Current Behavior: We observe that the hour values of the dt_afast_trabalho field are being altered during the process of converting from string to timestamp and subsequent processing in Hive and Spark.
