Skip to main content
rupakd
Silver ⭐️⭐️
Jun 26, 2019 12:08 AM UTC
Solved
Need suggestion for shell script for sqoop
I am new to hortonworks . I have created a shell script with the Sqoop import command . I want to execute the .sh script to run the sqoop import command .
I have tried the following :
1. I have uploaded the .sh script in a folder /home/scripts/sqoop_test.sh
2. The permission : -rwxr-xr-x 1 root root 215 Jun 25 18:44 sqoop_test.sh
3. Then I tried to run the file : ./sqoop_test.sh
4. I am getting the error : Permission denied: user=root, access=WRITE, inode="/user":hdfs:hdfs:drwxr-xr-x
My query is :
1. Do I need to upload the .sh script in a folder within HDFS
2. How do I setup the permission for the script so that it runs successfully
3. How to execute .sh file from within hdfs so that I do not get the permission denied error
Thanks
Shu_ashu
Shu_ashuAnswer
Gold ⭐️⭐️⭐️
Jun 26, 2019 12:51 AM UTC
@Rupak Dum
No need to upload .sh script to HDFS/
If you upload script to HDFS then follow this link to execute shell script from HDFS.
You are running sqoop import as root user for this case you need to change the permissions in HDFS for /user directory.
Refer to this and this link for similar kind of thread.
change the permissions of /user hdfs directory to 700 (or) 777, then you won't get any permission issues.
Shu_ashu
Shu_ashuAnswer
Gold ⭐️⭐️⭐️
@Rupak Dum
Translate
rupakd
rupakdAuthor
Silver ⭐️⭐️
Jun 26, 2019 1:32 AM UTC
@Shu
Thanks for your suggestion . I have changed the permission of the HDFS /user and the permission issue is gone and my sqoop command is running.
Translate
