Skip to main content
MYM
Bronze ⭐️⭐️⭐️
May 26, 2024 4:30 AM UTC
Question
NIFI failed to register flow with Flow Registry due to Read timed out
Recently, we have started experiencing issues with our NiFi commits in the NiFi Registry failing due to read timeout exceptions. The error message displayed is "Failed to register flow with Flow Registry due to Read timed out." However, despite this error, the commit in the NiFi Registry is actually successful. We are using the Git flow provider on the NiFi Registry side, and I can see a commit after every attempt, despite NiFi showing a timeout error.
Has anyone else encountered this issue, or does anyone have suggestions on how to resolve it? Any help would be greatly appreciated. Thanks in advance!
Here are the complete logs of exception:
2024-05-05 06:27:03,108 WARN [NiFi Web Server-599530] o.a.n.w.a.config.NiFiCoreExceptionMapper org.apache.nifi.web.NiFiCoreException: Failed to register flow with Flow Registry due to Read timed out. Returning Conflict response.
at org.apache.nifi.web.StandardNiFiServiceFacade.registerVersionedFlowSnapshot(StandardNiFiServiceFacade.java:5354)
at org.apache.nifi.web.StandardNiFiServiceFacade.registerFlowWithFlowRegistry(StandardNiFiServiceFacade.java:5026)
at org.apache.nifi.web.StandardNiFiServiceFacade$$FastClassBySpringCGLIB$$358780e0.invoke(<generated>)
at org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:218)
at org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.invokeJoinpoint(CglibAopProxy.java:793)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:163)
at org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.proceed(CglibAopProxy.java:763)
at org.springframework.aop.aspectj.MethodInvocationProceedingJoinPoint.proceed(MethodInvocationProceedingJoinPoint.java:89)
at org.apache.nifi.web.NiFiServiceFacadeLock.proceedWithReadLock(NiFiServiceFacadeLock.java:161)
at org.apache.nifi.web.NiFiServiceFacadeLock.registerLock(NiFiServiceFacadeLock.java:144)
at jdk.internal.reflect.GeneratedMethodAccessor2760.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.springframework.aop.aspectj.AbstractAspectJAdvice.invokeAdviceMethodWithGivenArgs(AbstractAspectJAdvice.java:634)
at org.springframework.aop.aspectj.AbstractAspectJAdvice.invokeAdviceMethod(AbstractAspectJAdvice.java:624)
at org.springframework.aop.aspectj.AspectJAroundAdvice.invoke(AspectJAroundAdvice.java:72)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
at org.springframework.aop.interceptor.ExposeInvocationInterceptor.invoke(ExposeInvocationInterceptor.java:97)
at org.springframework.aop.framework.CglibAopProxy$DynamicAdvisedInterceptor.intercept(CglibAopProxy.java:708)
at org.apache.nifi.web.StandardNiFiServiceFacade$$EnhancerBySpringCGLIB$$b11ae832.registerFlowWithFlowRegistry(<generated>)
at org.apache.nifi.web.api.VersionsResource.saveToFlowRegistry(VersionsResource.java:546)
at jdk.internal.reflect.GeneratedMethodAccessor2757.invoke(Unknown Source)
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory.lambda$static$0(ResourceMethodInvocationHandlerFactory.java:52)
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:134)
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:177)
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:176)
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:81)
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:475)
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:397)
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:81)
at org.glassfish.jersey.server.ServerRuntime$1.run(ServerRuntime.java:255)
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:248)
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:244)
at org.glassfish.jersey.internal.Errors.process(Errors.java:292)
at org.glassfish.jersey.internal.Errors.process(Errors.java:274)
at org.glassfish.jersey.internal.Errors.process(Errors.java:244)
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:265)
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:234)
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:684)
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:394)
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:346)
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:358)
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:311)
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:205)
at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1459)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1656)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:352)
at org.springframework.security.web.access.intercept.AuthorizationFilter.doFilter(AuthorizationFilter.java:100)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:361)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:126)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:120)
at org.apache.nifi.web.security.log.AuthenticationUserFilter.doFilterInternal(AuthenticationUserFilter.java:57)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:117)
at org.springframework.security.oauth2.server.resource.web.authentication.BearerTokenAuthenticationFilter.doFilterInternal(BearerTokenAuthenticationFilter.java:149)
at org.apache.nifi.web.security.NiFiAuthenticationFilter.authenticate(NiFiAuthenticationFilter.java:94)
at org.apache.nifi.web.security.NiFiAuthenticationFilter.doFilter(NiFiAuthenticationFilter.java:56)
at org.springframework.security.web.csrf.CsrfFilter.doFilterInternal(CsrfFilter.java:131)
at org.apache.nifi.web.security.csrf.SkipReplicatedCsrfFilter.doFilterInternal(SkipReplicatedCsrfFilter.java:59)
at org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:62)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:225)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:190)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:354)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:267)
at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:193)
at org.eclipse.jetty.servlet.ServletHandler$Chain.doFilter(ServletHandler.java:1626)
at org.apache.nifi.web.filter.ExceptionFilter.doFilter(ExceptionFilter.java:46)
at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:201)
at org.eclipse.jetty.servlets.DoSFilter.doFilterChain(DoSFilter.java:487)
at org.apache.nifi.web.server.filter.DataTransferExcludedDoSFilter.doFilterChain(DataTransferExcludedDoSFilter.java:51)
at org.eclipse.jetty.servlets.DoSFilter.doFilter(DoSFilter.java:336)
at org.eclipse.jetty.servlets.DoSFilter.doFilter(DoSFilter.java:301)
at org.springframework.security.web.header.HeaderWriterFilter.doHeadersAfter(HeaderWriterFilter.java:90)
at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:75)
at org.apache.nifi.web.server.log.RequestAuthenticationFilter.doFilterInternal(RequestAuthenticationFilter.java:59)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:552)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:505)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
at org.eclipse.jetty.server.handler.gzip.GzipHandler.handle(GzipHandler.java:772)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:191)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
at org.eclipse.jetty.server.Server.handle(Server.java:516)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:555)
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:410)
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:164)
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
at java.base/java.lang.Thread.run(Thread.java:829)
Caused by: java.net.SocketTimeoutException: Read timed out
at java.base/java.net.SocketInputStream.socketRead0(Native Method)
at java.base/java.net.SocketInputStream.socketRead(SocketInputStream.java:115)
at java.base/java.net.SocketInputStream.read(SocketInputStream.java:168)
at java.base/java.net.SocketInputStream.read(SocketInputStream.java:140)
at java.base/sun.security.ssl.SSLSocketInputRecord.read(SSLSocketInputRecord.java:478)
at java.base/sun.security.ssl.SSLSocketInputRecord.readHeader(SSLSocketInputRecord.java:472)
at java.base/sun.security.ssl.SSLSocketInputRecord.bytesInCompletePacket(SSLSocketInputRecord.java:70)
at java.base/sun.security.ssl.SSLSocketImpl.readApplicationRecord(SSLSocketImpl.java:1454)
at java.base/sun.security.ssl.SSLSocketImpl$AppInputStream.read(SSLSocketImpl.java:1065)
at java.base/java.io.BufferedInputStream.fill(BufferedInputStream.java:252)
at java.base/java.io.BufferedInputStream.read1(BufferedInputStream.java:292)
at java.base/java.io.BufferedInputStream.read(BufferedInputStream.java:351)
at java.base/sun.net.www.http.HttpClient.parseHTTPHeader(HttpClient.java:788)
at java.base/sun.net.www.http.HttpClient.parseHTTP(HttpClient.java:723)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1620)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1525)
at java.base/java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:527)
at java.base/sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(HttpsURLConnectionImpl.java:334)
at org.glassfish.jersey.client.internal.HttpUrlConnector._apply(HttpUrlConnector.java:378)
at org.glassfish.jersey.client.internal.HttpUrlConnector.apply(HttpUrlConnector.java:267)
at org.glassfish.jersey.client.ClientRuntime.invoke(ClientRuntime.java:297)
at org.glassfish.jersey.client.JerseyInvocation.lambda$invoke$1(JerseyInvocation.java:675)
at org.glassfish.jersey.client.JerseyInvocation.call(JerseyInvocation.java:697)
at org.glassfish.jersey.client.JerseyInvocation.lambda$runInScope$3(JerseyInvocation.java:691)
at org.glassfish.jersey.internal.Errors.process(Errors.java:205)
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:390)
at org.glassfish.jersey.client.JerseyInvocation.runInScope(JerseyInvocation.java:691)
at org.glassfish.jersey.client.JerseyInvocation.invoke(JerseyInvocation.java:674)
at org.glassfish.jersey.client.JerseyInvocation$Builder.method(JerseyInvocation.java:450)
at org.glassfish.jersey.client.JerseyInvocation$Builder.post(JerseyInvocation.java:351)
at org.apache.nifi.registry.client.impl.JerseyFlowSnapshotClient.lambda$create$0(JerseyFlowSnapshotClient.java:75)
at org.apache.nifi.registry.client.impl.AbstractJerseyClient.executeAction(AbstractJerseyClient.java:103)
at org.apache.nifi.registry.client.impl.JerseyFlowSnapshotClient.create(JerseyFlowSnapshotClient.java:69)
at org.apache.nifi.registry.flow.NifiRegistryFlowRegistryClient.registerFlowSnapshot(NifiRegistryFlowRegistryClient.java:269)
at org.apache.nifi.registry.flow.StandardFlowRegistryClientNode.lambda$registerFlowSnapshot$7(StandardFlowRegistryClientNode.java:247)
at org.apache.nifi.registry.flow.StandardFlowRegistryClientNode.execute(StandardFlowRegistryClientNode.java:282)
at org.apache.nifi.registry.flow.StandardFlowRegistryClientNode.registerFlowSnapshot(StandardFlowRegistryClientNode.java:247)
at org.apache.nifi.web.StandardNiFiServiceFacade.registerVersionedFlowSnapshot(StandardNiFiServiceFacade.java:5350)
... 138 common frames omitted
VidyaSargur
Community Manager
Community Manager
May 27, 2024 5:51 AM UTC
@MYM, Welcome to our community! To help you get the best possible answer, I have tagged in our NiFi experts @MattWho @RAGHUY @SAMSAL  who may be able to assist you further.
Please feel free to provide any additional information or details about your query, and we hope that you will find a satisfactory solution to your question.
Translate
Regards, Vidya Sargur, Community Manager Was your question answered? Make sure to mark the answer as the accepted solution. If you find a reply useful, say thanks by clicking on the thumbs up button.
Mini
Silver ⭐️⭐️
Jan 7, 2025 12:27 AM UTC
Hi,
Did you find any solution?
Translate
