NiFi MergeContent Behavior: How Max Bin Age Overrides Minimum Entries and Optimizes Heap Memory
Hi,
Just wanted to know how NiFi's MergeContent processor would behave when all 3 of these properties are set - 1) Correlation Attribute Name, 2) Minimum Number of Entries and 3) Max Bin Age; in my use case, the Correlation Attribute Name is the flowfile date (without the time stamp), since I want to merge files that are from the same day; I set the minimum number of entries, because the flowfiles come at varying intervals throughout the day and I wanted to have similar number of flowfiles in each merged file; at midnight, when the day crosses over to next day, the bin may not get filled because of these 2 criteria (same day files and min # of entries); does Max Bin Age act as an override, when the other 2 conditions are not satisfied, and tell MergeContent to create a merged file with whatever files are in the bin ? I'm thinking yes, but I wanted to confirm.
Thank you.
