Skip to main content
KPG1
Gold ⭐️
Dec 30, 2021 5:54 AM UTC
Solved
Not able to start Resource Manager using amabri but able to start using cli
I am facing an issue while starting resource manager using ambari but able to start it using CLI.
when starting using ambari no logs is generated in /var/log/haoop-yarn/ location.
Please find logs on ambari.
File "/usr/lib/ambari-agent/lib/resource_management/libraries/script/script.py", line 995, in restart
self.status(env)
File "/var/lib/ambari-agent/cache/stacks/HDP/3.0/services/YARN/package/scripts/resourcemanager.py", line 150, in status
check_process_status(status_params.resourcemanager_pid_file)
File "/usr/lib/ambari-agent/lib/resource_management/libraries/functions/check_process_status.py", line 43, in check_process_status
raise ComponentIsNotRunning()
The above exception was the cause of the following exception:
File "/var/lib/ambari-agent/cache/stacks/HDP/3.0/services/YARN/package/scripts/resourcemanager.py", line 261, in <module>
Resourcemanager().execute()
File "/usr/lib/ambari-agent/lib/resource_management/libraries/script/script.py", line 352, in execute
method(env)
File "/usr/lib/ambari-agent/lib/resource_management/libraries/script/script.py", line 1006, in restart
self.start(env, upgrade_type=upgrade_type)
File "/var/lib/ambari-agent/cache/stacks/HDP/3.0/services/YARN/package/scripts/resourcemanager.py", line 135, in start
self.configure(env) # FOR SECURITY
File "/var/lib/ambari-agent/cache/stacks/HDP/3.0/services/YARN/package/scripts/resourcemanager.py", line 62, in configure
yarn(name='resourcemanager')
File "/usr/lib/ambari-agent/lib/ambari_commons/os_family_impl.py", line 89, in thunk
return fn(*args, **kwargs)
File "/var/lib/ambari-agent/cache/stacks/HDP/3.0/services/YARN/package/scripts/yarn.py", line 369, in yarn
setup_atsv2_backend(name,config_dir)
File "/var/lib/ambari-agent/cache/stacks/HDP/3.0/services/YARN/package/scripts/yarn.py", line 637, in setup_atsv2_backend
setup_system_services(config_dir)
File "/var/lib/ambari-agent/cache/stacks/HDP/3.0/services/YARN/package/scripts/yarn.py", line 769, in setup_system_services
group=params.user_group
File "/usr/lib/ambari-agent/lib/resource_management/core/base.py", line 166, in __init__
self.env.run()
File "/usr/lib/ambari-agent/lib/resource_management/core/environment.py", line 160, in run
self.run_action(resource, action)
File "/usr/lib/ambari-agent/lib/resource_management/core/environment.py", line 124, in run_action
provider_action()
File "/usr/lib/ambari-agent/lib/resource_management/libraries/providers/hdfs_resource.py", line 677, in action_create_on_execute
self.action_delayed("create")
File "/usr/lib/ambari-agent/lib/resource_management/libraries/providers/hdfs_resource.py", line 674, in action_delayed
self.get_hdfs_resource_executor().action_delayed(action_name, self)
File "/usr/lib/ambari-agent/lib/resource_management/libraries/providers/hdfs_resource.py", line 373, in action_delayed
self.action_delayed_for_nameservice(None, action_name, main_resource)
File "/usr/lib/ambari-agent/lib/resource_management/libraries/providers/hdfs_resource.py", line 403, in action_delayed_for_nameservice
self._create_resource()
File "/usr/lib/ambari-agent/lib/resource_management/libraries/providers/hdfs_resource.py", line 419, in _create_resource
self._create_file(self.main_resource.resource.target, source=self.main_resource.resource.source, mode=self.mode)
File "/usr/lib/ambari-agent/lib/resource_management/libraries/providers/hdfs_resource.py", line 534, in _create_file
self.util.run_command(target, 'CREATE', method='PUT', overwrite=True, assertable_result=False, file_to_put=source, **kwargs)
File "/usr/lib/ambari-agent/lib/resource_management/libraries/providers/hdfs_resource.py", line 214, in run_command
return self._run_command(*args, **kwargs)
File "/usr/lib/ambari-agent/lib/resource_management/libraries/providers/hdfs_resource.py", line 282, in _run_command
_, out, err = get_user_call_output(cmd, user=self.run_user, logoutput=self.logoutput, quiet=False)
File "/usr/lib/ambari-agent/lib/resource_management/libraries/functions/get_user_call_output.py", line 62, in get_user_call_output
raise ExecutionFailed(err_msg, code, files_output[0], files_output[1])
resource_management.core.exceptions.ExecutionFailed: Execution of 'curl -sS -L -w '%{http_code}' -X PUT --data-binary @/usr/hdp/3.1.0.0-78/hadoop/conf/core-site.xml -H 'Content-Type: application/octet-stream' 'http://masternode:50070/webhdfs/v1/user/yarn-ats/3.1.0.0-78/core-site.xml?op=CREATE&user.name=hdfs&overwrite=True' 1>/tmp/tmpTdj1DW 2>/tmp/tmpJ4DHHk' returned 52. curl: (52) Empty reply from server
100
Thanks
KPG1
KPG1Answer
Gold ⭐️
May 26, 2022 10:00 AM UTC
I solved this by adding value as * in Hadoop.proxy.user.host in hdfs-core-site.xml
1 reply
KPG1
KPG1AuthorAnswer
Gold ⭐️
Translate
