Skip to main content
jarededrake
Silver ⭐️⭐️⭐️
Apr 12, 2022 3:47 PM UTC
Question
Oozie work flow not finding main class
Hello Community,
I am going through this tutorial https://www.cloudera.com/tutorials/setting-up-a-spark-development-environment-with-java.html and I am trying to submit it through Oozie work flow. In Hue I am going to Query > Scheduler > Workflow then dropping Java program to actions and then uploading jar file then adding the main class which is Hortonworks.SparkTutorial.Main. When I click to run the Oozie work flow job I keep getting the error of: "Caused by: java.lang.ClassNotFoundException: Class Hortonwork.SparkTutorial.Main not found". I'm using intelliJ to do this project so I hold down ctrl and hover over Main and it takes me to MANIFEST.MF file and it says Main-Class: Hortonworks.SparkTutorial.Main so I'm getting the main class definition right I feel like. I cannot figure out why it is saying it can't find my class.
mszurap
Platinum ⭐️
Platinum ⭐️
Apr 13, 2022 9:03 AM UTC
Hi @jarededrake , The "ClassNotFoundException: Class Hortonwork.SparkTutorial.Main not found" suggests that in the Java program's main class package name might have a typo (in your workflow definiton), the Hortonwork should be Hortonworks. Can you check that?
Translate
jarededrake
Silver ⭐️⭐️⭐️
Apr 14, 2022 3:18 PM UTC
@mszurap You were right I didn't have the "s" at the end 😐. However I am still getting the problem on oozie, I've add a screen shot so you can see the structure of my program and you can see in the MANIFEST.MF file it has my Main class as
Translate
mszurap
Platinum ⭐️
Platinum ⭐️
Apr 14, 2022 4:12 PM UTC
I see. Have you verified that the built jar contains this package structure and class names? Can you also show where the jar is uploaded and how is it referenced in the oozie workflow?
Thanks, Miklos
Translate
jarededrake
Silver ⭐️⭐️⭐️
Apr 15, 2022 3:11 PM UTC
I can yes I will get those screen shots to you
Translate
DianaTorres
Community Manager
Community Manager
May 3, 2022 8:23 PM UTC
@jarededrake Has the reply helped resolve your issue? If so, please mark the appropriate reply as the solution, as it will make it easier for others to find the answer in the future. Thanks!
Translate
Regards, Diana Torres, Senior Community Moderator
