Skip to main content
HiThere
Bronze ⭐️⭐️⭐️
Apr 12, 2022 12:05 PM UTC
Solved
Pro and Cons using VMs for CDP
Hi all, we are planing to use Vmware VMs for our production cluster for CDP 7.1.7. Is there any recommendation on the configurations, capacity and architecture from Cloudera on this?
Any link,whitepaper or documentation will be helpful.
What is the difference in performance in using VMs than using physical servers? Which one is preferred and why?
smdas
smdasAnswer
Gold ⭐️⭐️
Apr 14, 2022 8:29 AM UTC
Hello @HiThere
Thanks for using Cloudera Community. To your Query, Kindly refer [1] & [2] for Resource Requirement for CDP v7.1.7. Note that Documentation refers to Hardware requirement in terms of Resources (CPU, Memory, Network, Disk) as opposed to Physical Machines or Virtual Machines. As long as your Team meet the Hardware requirement for Storage & Compute, the Virtualized & Bare-Metal choices shouldn't matter.
Regards, Smarak
[1] https://docs.cloudera.com/cdp-private-cloud-base/7.1.7/installation/topics/cdpdc-hardware-requirements.html
[2] https://docs.cloudera.com/cdp-private-cloud-base/7.1.7/concepts/topics/cm-vpc-networking.html
smdas
Gold ⭐️⭐️
smdasAnswer
Gold ⭐️⭐️
Hello @HiThere
Regards, Smarak
Translate
smdas
Gold ⭐️⭐️
Gold ⭐️⭐️
Apr 19, 2022 8:05 AM UTC
Hello @HiThere
We hope your query concerning VMs & recommendations around Hardware is answered. We are marking the Post as Closed. If you have any further concerns, Feel free to post your ask & we shall answer your queries.
Regards, Smarak
Translate
