Problem for setting kudu.master_addresses property when use Impala Shell to create the Kudu table
I use the Impala Shell to create the Kudu table, but it need to insert TBLPROPERTIES ('kudu.master_addresses' = '...'); in the CREATE TABLE commands, and I tried to replace the kudu.master_addresses parameter values as follows:
- quickstart.cloudera:7051
- quickstart.cloudera:21000
- localhost:7051
- 10.0.2.15:7051
But I still get a RPC connection error message. How do I modify the parameter value or take other solutions?
(“Virtual machine working environment”, “Impala Shell commands and error messages” are shown as follows)
Virtual machine working environment:
Virtual Machine: Cloudera Quickstart Virtual Machine (Using Oracle VM Virtualbox, download URL: https://www.cloudera.com/downloads/quickstart_vms/5-13.html)
(1) Version: 5.13.0-0
(2) Number of processors: 2
(3) Controller: IDE Controller
(4) Memory space: 5120 MB
(5) Hard drive: 64.00 GB storage, solid state drive
(6) OS: Red Hat, 64-bit
(7) MySQL 5.1.73
(8) HBase 1.2.0-cdh5.13.0
(9) Hadoop 2.6.0-cdh5.13.0
(10) Impala 2.10.0-cdh5.13.0
Impala Shell commands and error messages:
Command #1
create table courses_kudu(
CID varchar,
title varchar,
credits int,
primary key(CID)
STORED AS KUDU
TBLPROPERTIES ('kudu.master_addresses'='quickstart.cloudera:7051');
ERROR: ImpalaRuntimeException: Error creating Kudu table 'impala::test_db.courses_kudu'
CAUSED BY: NonRecoverableException: can not complete before timeout: KuduRpc(method=ListTables, tablet=null, attempt=95, DeadlineTracker(timeout=180000, elapsed=178599), Traces: [0ms] querying master, [217ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [465ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [558ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [578ms] querying master, [578ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [580ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: [peer master-quickstart.cloudera:7051] unexpected exception from downstream on [id: 0xccd51009], [581ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: [peer master-quickstart.cloudera:7051] unexpected exception from downstream on [id: 0xccd51009], [593ms] querying master, [594ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [596ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [598ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [616ms] querying master, [616ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [618ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [620ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [635ms] querying master, [635ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [638ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [640ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [693ms] querying master, [693ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [695ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: [peer master-quickstart.cloudera:7051] unexpected exception from downstream on [id: 0x0ff834be], [696ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: [peer master-quickstart.cloudera:7051] unexpected exception from downstream on [id: 0x0ff834be], [753ms] querying master, [754ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [757ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [758ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [810ms] querying master, [810ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [812ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [813ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [853ms] querying master, [853ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [855ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [858ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [1271ms] querying master, [1271ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [1272ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [1274ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [1671ms] querying master, [1671ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [1672ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [1673ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [2670ms] querying master, [2671ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [2673ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: [peer master-quickstart.cloudera:7051] unexpected exception from downstream on [id: 0xada3b4be], [2674ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: [peer master-quickstart.cloudera:7051] unexpected exception from downstream on [id: 0xada3b4be], [3752ms] querying master, [3752ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [3754ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [3755ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [6310ms] querying master, [6310ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [6313ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [6322ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [8391ms] querying master, [8391ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [8393ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [8395ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [9191ms] querying master, [9191ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [9193ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: [peer master-quickstart.cloudera:7051] unexpected exception from downstream on [id: 0x7047d3ec], [9194ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: [peer master-quickstart.cloudera:7051] unexpected exception from downstream on [id: 0x7047d3ec], [12251ms] querying master, [12251ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [12253ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [12254ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [15031ms] querying master, [15031ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [15033ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [15036ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [17870ms] querying master, [17871ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [17872ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [17874ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [19252ms] querying master, [19252ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [19254ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [19256ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [20050ms] querying master, [20050ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [20052ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [20054ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [20432ms] querying master, [20432ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [20433ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [20434ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [23371ms] querying master, [23371ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [23372ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [23374ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [23810ms] querying master, [23811ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [23812ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: connection closed, [23813ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [24611ms] querying master, [24611ms] Sub rpc: ConnectToMaster sending RPC to server master-quickstart.cloudera:7051, [24613ms] Sub rpc: ConnectToMaster received from server master-quickstart.cloudera:7051 response Network error: [peer master-quickstart.cloudera:7051] unexpected exception from downstream on [id: 0xde44108b], [24615ms] delaying RPC due to Service unavailable: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: [peer master-quickstart.cloudera:7051] unexpected exception from downstream on [id: 0xde44108b], [28071ms] trace too long, truncated)
CAUSED BY: NoLeaderFoundException: Master config (quickstart.cloudera:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed
CAUSED BY: RecoverableException: connection closed
Command #2
CID varchar,
title varchar,
credits int,
primary key(CID)
STORED AS KUDU
TBLPROPERTIES (‘kudu.master_addresses'='quickstart.cloudera:21000');
Almost same as Command #1
Command #3
CID varchar,
title varchar,
credits int,
primary key(CID)
STORED AS KUDU
TBLPROPERTIES ('kudu.master_addresses'='localhost:7051');
CAUSED BY: NonRecoverableException: can not complete before timeout: KuduRpc(method=ListTables, tablet=null, attempt=99, DeadlineTracker(timeout=180000, elapsed=177778), Traces: [0ms] querying master, [864ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [2211ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [2568ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [2571ms] querying master, [2572ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [2575ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [2577ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [2591ms] querying master, [2591ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [2594ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [2596ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [2611ms] querying master, [2611ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [2614ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [2617ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [2631ms] querying master, [2631ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [2633ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [2635ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [2650ms] querying master, [2651ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [2692ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [2694ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [2752ms] querying master, [2752ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [2754ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [2755ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [2851ms] querying master, [2851ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [2852ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [2854ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [3051ms] querying master, [3051ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [3052ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [3054ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [3411ms] querying master, [3411ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [3414ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: [peer master-localhost:7051] unexpected exception from downstream on [id: 0xd8c820a8], [3418ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: [peer master-localhost:7051] unexpected exception from downstream on [id: 0xd8c820a8], [3651ms] querying master, [3651ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [3653ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: [peer master-localhost:7051] unexpected exception from downstream on [id: 0xc732a825], [3654ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: [peer master-localhost:7051] unexpected exception from downstream on [id: 0xc732a825], [3891ms] querying master, [3891ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [3893ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [3894ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [5872ms] querying master, [5872ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [5881ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [6035ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [8952ms] querying master, [8953ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [8954ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [8958ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [12894ms] querying master, [12894ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [12896ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [12909ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [14151ms] querying master, [14151ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [14153ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [14177ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [15330ms] querying master, [15331ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [15334ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [15418ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [16851ms] querying master, [16851ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [16853ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [16874ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [18211ms] querying master, [18212ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [18214ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [18217ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [19912ms] querying master, [19912ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [19915ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: [peer master-localhost:7051] unexpected exception from downstream on [id: 0xb7be219d], [19917ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: [peer master-localhost:7051] unexpected exception from downstream on [id: 0xb7be219d], [22332ms] querying master, [22333ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [22334ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [22335ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [23973ms] querying master, [23974ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [23977ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [23978ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [25351ms] querying master, [25351ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [25353ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [25355ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [28953ms] querying master, [28953ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [28957ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [28958ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [31032ms] querying master, [31036ms] Sub rpc: ConnectToMaster sending RPC to server master-localhost:7051, [31038ms] Sub rpc: ConnectToMaster received from server master-localhost:7051 response Network error: connection closed, [31040ms] delaying RPC due to Service unavailable: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [34411ms] trace too long, truncated)
CAUSED BY: NoLeaderFoundException: Master config (localhost:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed
Command #4
CID varchar,
title varchar,
credits int,
primary key(CID)
STORED AS KUDU
TBLPROPERTIES ('kudu.master_addresses'='10.0.2.15:7051');
CAUSED BY: NonRecoverableException: too many attempts: KuduRpc(method=ListTables, tablet=null, attempt=101, DeadlineTracker(timeout=180000, elapsed=165027), Traces: [0ms] querying master, [3ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [9ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [50ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [67ms] querying master, [68ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [71ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [83ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [103ms] querying master, [104ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [105ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [107ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [123ms] querying master, [124ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [126ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [128ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [143ms] querying master, [143ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [145ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [146ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [184ms] querying master, [184ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [186ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [187ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [246ms] querying master, [247ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [247ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [248ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [303ms] querying master, [304ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [305ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [306ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [323ms] querying master, [323ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [325ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [327ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [463ms] querying master, [464ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [466ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [467ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [1427ms] querying master, [1427ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [1429ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [1430ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [1603ms] querying master, [1604ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [1605ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: [peer master-10.0.2.15:7051] unexpected exception from downstream on [id: 0x717505ec], [1607ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: [peer master-10.0.2.15:7051] unexpected exception from downstream on [id: 0x717505ec], [1707ms] querying master, [1707ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [1708ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [1709ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [5404ms] querying master, [5405ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [5406ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [5407ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [6184ms] querying master, [6184ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [6185ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [6187ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [6324ms] querying master, [6324ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [6326ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [6328ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [7583ms] querying master, [7584ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [7586ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [7587ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [8865ms] querying master, [8865ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [8867ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [8868ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [9645ms] querying master, [9646ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [9647ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [9648ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [10805ms] querying master, [10806ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [10808ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [10809ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [12024ms] querying master, [12024ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [12026ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [12027ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [12567ms] querying master, [12568ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [12570ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [12576ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [15324ms] querying master, [15325ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [15327ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [15328ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [18205ms] querying master, [18205ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [18207ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [18208ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [20343ms] querying master, [20343ms] Sub rpc: ConnectToMaster sending RPC to server master-10.0.2.15:7051, [20345ms] Sub rpc: ConnectToMaster received from server master-10.0.2.15:7051 response Network error: connection closed, [20346ms] delaying RPC due to Service unavailable: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed, [22308ms] trace too long, truncated)
CAUSED BY: NoLeaderFoundException: Master config (10.0.2.15:7051) has no leader. Exceptions received: org.apache.kudu.client.RecoverableException: connection closed
