Skip to main content
yagoaparecidoti
Gold ⭐️
Jul 8, 2022 3:46 PM UTC
Solved
Problem kafka producer - WARN clients.NetworkClient: [Producer clientId=console-producer] Bootstrap broker
we are using kafka 2.2.1 in cloudera manager with cdh6.3.2
when we try to run kafka producer:
kafka-console-producer --broker-list ip-172-31-13-30.us-east-2.compute.internal:9092,ip-172-31-12-151.us-east-2.compute.internal:9092,ip-172-31-14-136.us-east-2.compute.internal:9092 --topic test_topic
returns the errors:
22/07/08 12:36:16 WARN clients.NetworkClient: [Producer clientId=console-producer] Bootstrap broker ip-172-31-14-136.us-east-2.compute.internal:9092 (id: -3 rack: null) disconnected
22/07/08 12:36:16 WARN clients.NetworkClient: [Producer clientId=console-producer] Bootstrap broker ip-172-31-12-151.us-east-2.compute.internal:9092 (id: -2 rack: null) disconnected
22/07/08 12:36:16 WARN clients.NetworkClient: [Producer clientId=console-producer] Bootstrap broker ip-172-31-13-30.us-east-2.compute.internal:9092 (id: -1 rack: null) disconnected
when we check the logs of kafka brokers there is:
2022-07-08 12:36:17,365 INFO org.apache.kafka.common.network.Selector: [SocketServer brokerId=89] Failed authentication with /172.31.9.160 (Unexpected Kafka request of type METADATA during SASL handshake.)
2022-07-08 12:34:11,776 INFO org.apache.kafka.common.network.Selector: [SocketServer brokerId=88] Failed authentication with /172.31.9.160 (Unexpected Kafka request of type METADATA during SASL handshake.)
2022-07-08 12:34:11,505 INFO org.apache.kafka.common.network.Selector: [SocketServer brokerId=90] Failed authentication with /172.31.9.160 (Unexpected Kafka request of type METADATA during SASL handshake.)
We would like to know why this problem is occurring?
ps: we are managing to list the topics without problem
bgoerlitz
bgoerlitzAnswer
Gold ⭐️
Jul 8, 2022 6:31 PM UTC
These errors on the client side usually indicate a security misconfiguration, and based on the broker log messages you sent, I would guess that you have Kerberos enabled for this cluster ("SASL handshake" suggests kerberos is expected). When anything other than PLAINTEXT (no security) is used, you will need to provide a client configuration file specifying the security properties.
Since the specific values of those properties would be dependent on your environment, I'd recommend that you review steps 7 and following in the Kafka Security - Enabling Kerberos Authentication documentation. Here is a link to that section
https://docs.cloudera.com/documentation/enterprise/6/6.3/topics/kafka_security.html#kafka_kerberos
I hope that helps!
bgoerlitz
Gold ⭐️
bgoerlitzAnswer
Gold ⭐️
I hope that helps!
Translate
DianaTorres
Community Manager
Community Manager
Jul 11, 2022 6:52 PM UTC
@yagoaparecidoti Has the reply helped resolve your issue? If so, please mark the appropriate reply as the solution, as it will make it easier for others to find the answer in the future. Thanks
Translate
Regards, Diana Torres, Senior Community Moderator
