Skip to main content
CJ-Llanes
Silver ⭐️
Mar 24, 2022 1:48 AM UTC
Solved
Problems to load aws credentials to nifi
I'm trying to connect to dynamo db from nifi processor component "PutDynamoDB"
I'm putting my secret key in the field Access Key ID
secret key in Secret Access Key
and the path of the credentials in the format:
[default]
aws_access_key_id=<key id>
aws_secret_access_key=<access key>
At the moment of make the validation i get this message:
Perform Validation
Component is invalid: '' validated against 'Access Key' is invalid because Cannot set both Credentials File and Secret Key/Access Key
Does someone have an idea about this? I haven't foun anything related
araujo
araujoAnswer
Platinum ⭐️⭐️⭐️
Mar 24, 2022 9:44 AM UTC
@CJ-Llanes ,
You cannot specifie the Access Key ID, Secret Access Key and the credentials file path.
They are mutually exclusive.
You must either:
  • Specify only Access Key ID and Secret Access Key
OR
  • Specify only the credentials file path
But not both.
Cheers,
André
Was your question answered? Please take some time to click on "Accept as Solution" below this post.
-- Was your question answered? Please take some time to click on "Accept as Solution" below this post. If you find a reply useful, say thanks by clicking on the thumbs up button.
araujo
Platinum ⭐️⭐️⭐️
araujoAnswer
Platinum ⭐️⭐️⭐️
@CJ-Llanes ,
You must either:
OR
But not both.
Cheers,
André
Translate
CJ-Llanes
CJ-LlanesAuthor
Silver ⭐️
Mar 24, 2022 3:21 PM UTC
Thank you, it was that.
Translate
