PrometheusReportingTask with same port and multiple nifi instances on same machine
I am using Nifi 1.12.1 version and configuring Prometheus for monitoring. I have multiple nifi instances running on the same machine. But I am not able to get metrics for all on the same port 9092 and getting below error in nifi log.
From 3 nifi instances, only one nifi is able to start Prometheus reporting task properly others are saying Address already in use as displayed in error below.
Can't we change the Prometheus metrics endpoint from nifi? For example for each nifi instance, we should be able to use a different metric endpoint in below way.
- nifi-1 - 9092/metrics (default metric end point)
- nifi-2 >>> 9092/nifi_2_metrics
- nifi-3 >>> 9092/nifi_3_metrics
2021-05-10 09:55:39,957 ERROR [Timer-Driven Process Thread-4] o.a.n.c.s.StandardProcessScheduler Failed to invoke the On-Scheduled Lifecycle methods of [PrometheusReportingTask[id=47b5aa61-0179-1000-ce9d-d59160596cdb], java.lang.reflect.InvocationTargetException, 30 sec] due to {}; administratively yielding this ReportingTask and will attempt to schedule it again after {}
java.lang.reflect.InvocationTargetException: null
at jdk.internal.reflect.GeneratedMethodAccessor74.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.apache.nifi.util.ReflectionUtils.invokeMethodsWithAnnotations(ReflectionUtils.java:142)
at org.apache.nifi.util.ReflectionUtils.invokeMethodsWithAnnotations(ReflectionUtils.java:130)
at org.apache.nifi.util.ReflectionUtils.invokeMethodsWithAnnotations(ReflectionUtils.java:75)
at org.apache.nifi.util.ReflectionUtils.invokeMethodsWithAnnotation(ReflectionUtils.java:52)
at org.apache.nifi.controller.scheduling.StandardProcessScheduler$2.run(StandardProcessScheduler.java:222)
at org.apache.nifi.engine.FlowEngine$2.run(FlowEngine.java:110)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: org.apache.nifi.processor.exception.ProcessException: Failed to start Jetty server
at org.apache.nifi.reporting.prometheus.PrometheusReportingTask.onScheduled(PrometheusReportingTask.java:152)
... 15 common frames omitted
Caused by: java.io.IOException: Failed to bind to /0.0.0.0:9092
at org.eclipse.jetty.server.ServerConnector.openAcceptChannel(ServerConnector.java:346)
at org.eclipse.jetty.server.ServerConnector.open(ServerConnector.java:307)
at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:80)
at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:231)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:72)
at org.eclipse.jetty.server.Server.doStart(Server.java:385)
at org.apache.nifi.reporting.prometheus.PrometheusServer.<init>(PrometheusServer.java:90)
at org.apache.nifi.reporting.prometheus.PrometheusReportingTask.onScheduled(PrometheusReportingTask.java:115)
Caused by: java.net.BindException: Address already in use
at java.base/sun.nio.ch.Net.bind0(Native Method)
at java.base/sun.nio.ch.Net.bind(Net.java:455)
at java.base/sun.nio.ch.Net.bind(Net.java:447)
at java.base/sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:227)
at java.base/sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:80)
at org.eclipse.jetty.server.ServerConnector.openAcceptChannel(ServerConnector.java:342)
... 23 common frames omitted
