Skip to main content
lbourgeois
Silver ⭐️⭐️
Jan 17, 2024 2:11 PM UTC
Solved
Using Hadoop Iceberg catalog with Hive engine on CDP 7.2
Hello,
Based on this example in Iceberg doc I tried to create a table using a custom hadoop catalog.
Using Hue in CDP 7.2 I performed
SET iceberg.catalog.hadoop_cat.type=hadoop;
SET iceberg.catalog.hadoop_cat.warehouse=s3a://my-bucket/hadoop_cat_warehouse;
CREATE TABLE iceberg_hadoop_cat_table (id Integer,name String) STORED BY 'org.apache.iceberg.mr.hive.HiveIcebergStorageHandler' TBLPROPERTIES ('iceberg.catalog'='hadoop_cat');
But received
Error while compiling statement: FAILED: Execution Error, return code 40000 from org.apache.hadoop.hive.ql.ddl.DDLTask. java.lang.IllegalArgumentException: Table location not set
Did I miss something ? Is CDP suporting that ?
Thanks,
Laurent
ggangadharan
Gold ⭐️
Sep 5, 2025 2:19 PM UTC
use the following command.
CREATE EXTERNAL TABLE ice_t (i int, s string) STORED BY ICEBERG;
jAnshula
Gold ⭐️
Gold ⭐️
Feb 15, 2024 2:44 PM UTC
Hi @lbourgeois
Can you try creating table using CREATE EXTERNAL TABLE command.
Let us know if this works
Translate
ggangadharan
Gold ⭐️
Gold ⭐️
Translate
VidyaSargur
Community Manager
Community Manager
Sep 8, 2025 6:04 AM UTC
@lbourgeois, Did the response assist in resolving your query? If it did, please mark the relevant reply as the solution, as it will help others locate the answer more easily in the future.
Translate
Regards, Vidya Sargur Madabhushi| Senior Community Manager | Was your question answered? Make sure to mark the answer as the Best Answer. If you find a reply useful, say thanks by clicking on the thumbs up button.
