Skip to main content
Hadoop_dev
Gold ⭐️
Mar 22, 2021 1:12 PM UTC
Solved
Will updating hive.notification.sequence.lock.max.retries cause SocketTimeOut exception?
Hi,
We  recently updated  value of hive.notification.sequence.lock.max.retries from 20 to 40 and started getting multiple SocketTimeOut Failures
Caused by: java.io.IOException: java.net.SocketTimeoutException: 60000 millis timeout while waiting for channel to be ready for read. ch : java.nio.channels.SocketChannel[connected local=/10.2.1.11:49971 remote=node011.mapreduce.net/10.2.8.4:45454]
at org.apache.hadoop.ipc.Client$Connection$1.run(Client.java:685).  .
.Is this related?
Hadoop_dev
Gold ⭐️
Mar 30, 2021 8:37 AM UTC
Hi,
I Saw this error while  select data  from one hive table and insert it to other.  It is resolved now  after restarting yarn.
mugdha
Gold ⭐️⭐️
Gold ⭐️⭐️
Mar 23, 2021 1:23 AM UTC
The 'hive.notification.sequence.lock.max.retries' Parameter detects the number of retries for acquiring a Lock for getting the Next Notification ID for entries in the 'NOTIFICATION_LOG' Table.
The error that you are seeing does seem to be because of this. Add more context, when are you seeing this? What job are you running? Full trace?
Translate
Hadoop_dev
Hadoop_devAuthorAnswer
Gold ⭐️
Hi,
Translate
