Skip to main content
mike_bronson7
Gold ⭐️⭐️⭐️
February 20, 2020
Solved
ambari metrics collector not display the metrics after moving to distributed mode
hi all
we have HDP version 2.6.5 and ambari 2.6.2.2
we configured the following
Metrics Service operation mode=distributed
hbase.rootdir=hdfs://hdfsha:8020/user/ams/hbase
and all the rest according to - https://cwiki.apache.org/confluence/display/AMBARI/AMS+-+distributed+mode
so ambari configured to save the data on hdfs instead the local disk
after metrics collector service restart we saw the following from log
2020-02-20 20:09:15,770 INFO [timeline] timeline.HadoopTimelineMetricsSink: No live collector to send metrics to. Metrics to be sent will be discarded. This message will be skipped for the next 20 times.
2020-02-20 20:11:35,769 INFO [timeline] timeline.HadoopTimelineMetricsSink: No live collector to send metrics to. Metrics to be sent will be discarded. This message will be skipped for the next 20 times.
and
2020-02-20 20:30:10,306 INFO org.apache.hadoop.metrics2.impl.MetricsSystemImpl: phoenix metrics system started
2020-02-20 20:30:10,450 WARN org.apache.hadoop.hbase.io.util.HeapMemorySizeUtil: hbase.regionserver.global.memstore.upperLimit is deprecated by hbase.regionserver.global.memstore.size
2020-02-20 20:30:15,327 WARN org.apache.hadoop.hbase.io.util.HeapMemorySizeUtil: hbase.regionserver.global.memstore.upperLimit is deprecated by hbase.regionserver.global.memstore.size
and without metrics as
and after some time the metrics collector service failed
why this happens ?
NOTE - I must to say that - when data of metrics saved on local disk then everything was ok
is that because reaching data on HDFS is more slow?
jsensharma
Platinum ⭐️⭐️
February 20, 2020
@mike_bronson7
This does not look right? Ideally with HDFS HA name we do not use the Port number because "hdfsha" is not a hostname but just a logical name.
If you NameService name is "hdfsha" (defined in "Custom core-site" as "dfs.nameservices=hdfsha") then ideally you should be using the following in your AMS configuration in your "Advanced ams-hbase-site"
hbase.rootdir=/user/ams/hbase
. As your AMS mode is "distributed" hence AMS will automatically assume that the data is in HDFS and will be able to figure out the actual NameService name dynamically so we do not even need to specify "hdfs://hdfsha" there.   After fixing the "hbase.rootdir" in AMS configs please kill and restart the AMS processes. Then specially check the AMS logs specially the following logs and please share if you notice any error ... please share the Full stacktrace.
/var/log/ambari-metrics-collector/hbase-ams-master-*.log
/var/log/ambari-metrics-collector/hbase-ams-region-*.log
/var/log/ambari-metrics-collector/ambari-metrics-collector.log
jsensharma
Platinum ⭐️⭐️
Platinum ⭐️⭐️
February 20, 2020
@mike_bronson7
Translate
mike_bronson7
Gold ⭐️⭐️⭐️
February 21, 2020
Dear jay
do you mean to set it as
or
Translate
Michael-Bronson
jsensharma
Platinum ⭐️⭐️
Platinum ⭐️⭐️
February 21, 2020
@mike_bronson7
As the Metrics Service operation mode is already selected to "distributed" hence Ambari will make AMS aware that it needs to find that hbase.rootdir on HDFS.
Following should be fine.
Translate
