pass parameters to file with sql statement using Scala to be used sqlContext.sql(string)
I am using Scala on data science workbench and I have file with sql stataement would like to make it dynamic sql by passing argument to parameters. I then would like to pass it sqlContext.sql(string) .
This is what I have tried but does not work.
val FromDate = "2019-02-25"
val sqlfile = fromFile("sql3.py").getLines.mkString
val result = sqlContext.sql(sqlfile)
On the file I have:
Select col1, col2 from table1 where transdate = '${FromDate}'
Any help would be appreciated.
Thanks
