Skip to main content
phir1
Silver ⭐️⭐️
September 8, 2022
Solved
Retrieving HDFS Groups and users using programming
Hello,
Is there a way to retrieve all HDFS groups and respective users, in Cloudera, using Java or Scala/Spark code?
In other words, I’m looking for Java/Scala code equivalent to "hdfs groups <user1>, <user2>, ...".
Ideally, the code would run in Zeppelin.
Many thanks.
James G
James GAnswer
Gold ⭐️
September 8, 2022
Try this
hdfs groups hdfs solr
ale241290xdf
Silver ⭐️⭐️
Silver ⭐️⭐️
September 8, 2022
@phir1
I can think of something like a for maybe:
# for i in `cat <users_file>`; do hdfs groups $i; done
Translate
phir1
phir1Author
Silver ⭐️⭐️
September 8, 2022
Hi,
thank you for your suggestion, but I’m looking for example Java or Scala code that uses the Hadoop or Cloudera API, instead of scripting the « hdfs » tool on Linux.
Translate
James G
Gold ⭐️
James GAnswer
Gold ⭐️
September 8, 2022
Try this
Translate
