Support Questions
Problem with Zeppelin using Spark and Livy
Hi,
i have a problem with Zeppelin using Livy interpreter with Spark2 2.3.2 and Hive 3.1.0.
The cluster have Ambari 2.7.3, HDP-3.1.0 and kerberos installed.
Normal Spark without Livy works fine with LLAP. No problem there at all.
But when i try to execut a job like the this
%livy2.spark
val hive = com.hortonworks.spark.sql.hive.llap.HiveWarehouseBuilder.session(spark).build
hive.execute("select count (*) from <table_name>").show
i retrive the following error
java.lang.RuntimeException: java.sql.SQLException: Cannot create PoolableConnectionFactory (Could not open client transport for any of the Server URI's in ZooKeeper: Could not establish connection to jdbc:hive2://<edge_hostname>:10001/;serviceDiscoveryMode=zooKeeper;zooKeeperNamespace=hiveserver2;auth=delegationToken: HTTP Response code: 401)
  at com.hortonworks.spark.sql.hive.llap.HiveWarehouseSessionImpl.execute(HiveWarehouseSessionImpl.java:70)
  ... 50 elided
Caused by: java.sql.SQLException: Cannot create PoolableConnectionFactory (Could not open client transport for any of the Server URI's in ZooKeeper: Could not establish connection to jdbc:hive2://<edge_hostname>:10001/;serviceDiscoveryMode=zooKeeper;zooKeeperNamespace=hiveserver2;auth=delegationToken: HTTP Response code: 401)
  at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2291)
  at org.apache.commons.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:2038)
  at org.apache.commons.dbcp2.BasicDataSource.getLogWriter(BasicDataSource.java:1588)
  at org.apache.commons.dbcp2.BasicDataSourceFactory.createDataSource(BasicDataSourceFactory.java:588)
  at com.hortonworks.spark.sql.hive.llap.JDBCWrapper.getConnector(HS2JDBCWrapper.scala:333)
  at com.hortonworks.spark.sql.hive.llap.JDBCWrapper.getConnector(HS2JDBCWrapper.scala:340)
  at com.hortonworks.spark.sql.hive.llap.DefaultJDBCWrapper.getConnector(HS2JDBCWrapper.scala)
  at com.hortonworks.spark.sql.hive.llap.HiveWarehouseSessionImpl.lambda$new$0(HiveWarehouseSessionImpl.java:48)
  at com.hortonworks.spark.sql.hive.llap.HiveWarehouseSessionImpl.execute(HiveWarehouseSessionImpl.java:66)
  ... 50 more
Caused by: java.sql.SQLException: Could not open client transport for any of the Server URI's in ZooKeeper: Could not establish connection to jdbc:hive2://<edge_hostname>:10001/;serviceDiscoveryMode=zooKeeper;zooKeeperNamespace=hiveserver2;auth=delegationToken: HTTP Response code: 401
  at shadehive.org.apache.hive.jdbc.HiveConnection.<init>(HiveConnection.java:333)
  at shadehive.org.apache.hive.jdbc.HiveDriver.connect(HiveDriver.java:107)
  at org.apache.commons.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:39)
  at org.apache.commons.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:256)
  at org.apache.commons.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:2301)
  at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2287)
  ... 58 more
Caused by: java.sql.SQLException: Could not establish connection to jdbc:hive2://<edge_hostname>:10001/;serviceDiscoveryMode=zooKeeper;zooKeeperNamespace=hiveserver2;auth=delegationToken: HTTP Response code: 401
  at shadehive.org.apache.hive.jdbc.HiveConnection.openSession(HiveConnection.java:815)
  at shadehive.org.apache.hive.jdbc.HiveConnection.<init>(HiveConnection.java:305)
  ... 63 more
Caused by: org.apache.thrift.transport.TTransportException: HTTP Response code: 401
  at org.apache.thrift.transport.THttpClient.flushUsingHttpClient(THttpClient.java:262)
  at org.apache.thrift.transport.THttpClient.flush(THttpClient.java:313)
  at org.apache.thrift.TServiceClient.sendBase(TServiceClient.java:73)
  at org.apache.thrift.TServiceClient.sendBase(TServiceClient.java:62)
  at shadehive.org.apache.hive.service.rpc.thrift.TCLIService$Client.send_OpenSession(TCLIService.java:170)
  at shadehive.org.apache.hive.service.rpc.thrift.TCLIService$Client.OpenSession(TCLIService.java:162)
  at shadehive.org.apache.hive.jdbc.HiveConnection.openSession(HiveConnection.java:796)
  ... 64 more
There is the settings for Livy interpreter
livy.spark.hadoop.hive.llap.daemon.service.hosts	@llap0
livy.spark.hadoop.hive.zookeeper.quorum			<zk_host1>:2181;<zk_host2>:2181;<zk_host3>:2181
livy.spark.security.credentials.hiveserver2.enabled	true
livy.spark.sql.hive.hiveserver2.jdbc.url		jdbc:hive2://<zk_host1>:2181,<zk_host2>:2181,<zk_host3>:2181/;serviceDiscoveryMode=zooKeeper;zooKeeperNamespace=hiveserver2
livy.spark.sql.hive.hiveserver2.jdbc.url.principal	hive/_<kerberos_principal>
I checked many times all the configuration settings but they're set like the documentation.
Can someone help me?
Thanks
4 REPLIES 4
Re: Problem with Zeppelin using Spark and Livy
Mentor
@Marco Caron
The problem you are encountering is the misconfiguration of the jdbc connection. Response code :401 HTTP response status code indicates that the request sent by the client could not be authenticated. Have a look at this HCC document connect HS2 connect strings
Under Advanced hive-interactive-site, the HiveServer2 port is typically 10500 can you check the values on your cluster?
HTH
Hi,
under Advanced hive-interactive-site, the HiveServer2 port is set to 10500
Mentor
@Marco Caron
Any updates on this issue ,do you still need help to resolve the problem?
Mentor
@Marco Caron
Don't have an account?
