Archives of Support Questions (Read Only)
This is an archived board for historical reference. Information and links may no longer be available or relevant
This board is archived and read-only for historical reference. To ask a new question, please post a new topic on the appropriate active board.
Container metrics do not match between spark UI and YARN resourcemanager UI
New Member
I am tuning a spark application and noticed there are discrepancies between the job's metrics shown on Spark's history server UI and YARN's resource manager UI.
I've specified the the following properties on my Zeppelin Notebook's spark interpreter:
masteryarn-client
spark.app.nameZeppelin
spark.cores.max
spark.driver.memory3g
spark.executor.cores3
spark.executor.instances2
spark.executor.memory4g
When I look at the YARN ResourceManager UI I do not see evidence that the executor's containers are getting 3 cores each. I see that they each are using 1 v-core each.
Yet, when I check the Spark History Server... it describes each running executor has 3 cores and reflects all the properties I've specified.
What's up with this? Which of these should I be looking at?
YARN 3.1.0 Zeppelin 0.8.0 Spark2 2.3.1
1 ACCEPTED SOLUTION
@Matt Krueger you should look at spark history server/spark ui to see the correct environment settings being used. Setting executor cores to 3 is actually going to use 3 concurrent threads in each executor. AFAIK this might not be same as yarn v-core concept.
HTH
*** If you found this answer addressed your question, please take a moment to login and click the "accept" link on the answer.
1 REPLY 1
HTH
