Archives of Support Questions (Read Only)
This is an archived board for historical reference. Information and links may no longer be available or relevant
This board is archived and read-only for historical reference. To ask a new question, please post a new topic on the appropriate active board.
Problem installing j2sdk using parcel files
I am trying to install using the following process but using a custom parcel repo
Installation Path B - Manual Installation Using Cloudera Manager Packages
I have created a custom repo and have started the httpd service.
The httpd services list my parcels and the manifest.json
I use CentOS 6.6 and installing CDH5.47
 I have configured my custom repos under /etc/yum.repos.d which points to the parcel file
when I try to install  oracle-j2sdk1.7 as specifed in step 3 at Installation Path B - Manual Installation Using Cloudera Manager Packages I get the follwing message.
sudo yum install oracle-j2sdk1.7
Loaded plugins: fastestmirror, security
Setting up Install Process
Loading mirror speeds from cached hostfile
* base: mirror.chpc.utah.edu
* extras: mirror.spro.net
* updates: ftp.osuosl.org
Nothing to do
when I do yum repolist  I get the following error. It doesn't extract or consider the parcel files
http://<IP>/cdh-5.4.7/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
Trying other mirror.
Any help is really appreciated. Thanks
1 ACCEPTED SOLUTION
fixed it, j2sdk in the manager using yum should be using a  tar ball repo configured in your local repo
1 REPLY 1
