Created on 06-02-2016 11:08 AM - edited 08-19-2019 03:56 AM
I'm running through the Getting Started with HDP tutorial Lab 7 and consistently getting errors when trying to validate the Hive (via Tez) JDBC url within Zoomdata. Hive (and the rest of the HDP) is running in well in a sandbox VM.
I have the following installed and working as per the instructions:
All HDP services (including Hive) have started correctly and on the Zoomdata side I have configured connector-HIVE_ON_TEZ=true as supervisor. In the Zoomdata UI when I try to define the JDBC url (as the admin user) I receive the error 'Failed to validate connection' (see attached image).
Can anyone suggest what I need to look at to get this to work? I am wondering whether this is a VM network issue.
Many thanks!
Created 06-08-2016 11:46 PM
It will not work out of the box because HDP 2.4 Sandbox has an Atlas Bridge that's throwing the error on the post Hive hook. This happens for any query involving a "dummy" database (e.g., "select 1").
Via the Ambari config for Hive you should locate the hive.exec.post.hooks property. It will have a value like this:
org.apache.hadoop.hive.ql.hooks.ATSHook, org.apache.atlas.hive.hook.HiveHook
You should remove the second hook (the Atlas hook) so the property only reads:
Lastly, restart the Hive server. You should be able to verify the fix even without Zoomdata by executing in Hive (via Ambari or Beeline):
select count(1);
If the query is working, Zoomdata should have no problem connecting to HDP's Hive.
Hope this helps!
Created 06-15-2016 07:07 PM
No problem Rafael, glad it works for you now.
It sounds like it was a problem with the networking of the containers that for whatever reason they couldn't establish a connection. Hopefully it doesn't manifest again!
