Community Articles
If you have ever run Cloudera Edge Flow Manager (EFM) out of the box on Kubernetes, you know the sad little moment when the pod restarts and every agent class, every flow, and every resource you painstakingly uploaded is just… gone. EFM’s default persistence lives inside the pod’s ephemeral filesystem, and unless you wire it up properly it never sees a second day.
This post is the recipe I keep coming back to for running EFM 2.3.1.0-2 on minikube with full persistence. All state survives kubectl rollout restart, minikube stop, or the laptop lid closing on you at the wrong moment.
Three things need a permanent home:
  • Metadata (agent classes, flows, agents, manifests) → PostgreSQL
  • Agent binaries (MiNiFi C++ / Java installers) → a PVC
  • Uploaded resources (Python scripts, JARs, custom assets) → a second PVC
The third one is the piece a bare EFM install always loses on restart, and it is the reason this post exists.
1. PrerequisitesPermalink
You will need a running minikube cluster with:
  • Installed Cloudera Streaming Operators in the cld-streaming namespace
  • A PostgreSQL pod (I use ssb-postgresql from the SSB stack) — this becomes EFM’s backing store
  • Kafka pods if your flows publish to Kafka
  • Access to container.repo.cloudera.com (your Cloudera entitlement)
Confirm they are all up:
kubectl get pods -n cld-streaming | grep -E "postgres|kafka"
2. Create the EFM Database in PostgreSQLPermalink
EFM needs its own database and user inside the existing Postgres. One-time setup:
PG=$(kubectl get pods -n cld-streaming | grep postgres | awk '{print $1}' | head -1)
kubectl exec $PG -n cld-streaming -- psql -U postgres -c "CREATE DATABASE efm;"
kubectl exec $PG -n cld-streaming -- psql -U postgres -c "CREATE USER efm WITH PASSWORD 'efm_password';"
kubectl exec $PG -n cld-streaming -- psql -U postgres -c "GRANT ALL PRIVILEGES ON DATABASE efm TO efm;"
kubectl exec $PG -n cld-streaming -- psql -U postgres -c "ALTER DATABASE efm OWNER TO efm;"
3. Create the SecretsPermalink
Three secrets: the DB password, the EFM encryption password, and the Cloudera registry pull secret.
kubectl create secret generic efm-db-pass \
  --from-literal=password=efm_password \
  --namespace cld-streaming
kubectl create secret generic efm-encryption \
  --from-literal=encryption.password=efm_encryption_key \
source ~/.env
kubectl create secret docker-registry cloudera-registry \
  --docker-server=container.repo.cloudera.com \
  --docker-username=$CLOUDERA_USER \
  --docker-password=$CLOUDERA_PASS \
  --namespace=cld-streaming
Warning! already exists errors from prior sessions are fine — skip those.
4. Pull the EFM Image into MinikubePermalink
eval $(minikube docker-env)
docker login container.repo.cloudera.com
docker pull container.repo.cloudera.com/cloudera/efm:2.3.1.0-2
Match the tag to your CSO / CEM entitlement.
5. The ConfigMapPermalink
Save the following as efm-configMap.yaml. This is the full efm.properties file, and the important part is the efm.db.* block — that is what points EFM at Postgres instead of its default embedded H2 database.
apiVersion: v1
kind: ConfigMap
metadata:
  namespace: cld-streaming
data:
  efm.properties: |
    # Web Server Properties
    efm.server.address=0.0.0.0
    efm.server.port=10090
    efm.server.servlet.contextPath=/efm
    # Cluster Properties
    efm.cluster.enabled=false
    # Web Server TLS Properties
    efm.server.ssl.enabled=false
    efm.server.ssl.keyStore=./conf/keystore.jks
    efm.server.ssl.keyStoreType=jks
    efm.server.ssl.keyStorePassword=
    efm.server.ssl.keyPassword=
    efm.server.ssl.trustStore=./conf/truststore.jks
    efm.server.ssl.trustStoreType=jks
    efm.server.ssl.trustStorePassword=
    efm.server.ssl.clientAuth=WANT
    # User Authentication Properties
    efm.security.user.auth.enabled=false
    efm.security.user.auth.adminIdentities=admin
    efm.security.user.auth.autoRegisterNewUsers=true
    efm.security.user.auth.authTokenExpiration=12h
    efm.security.user.auth.groups.manager=INTERNAL
    efm.security.user.auth.groups.adminIdentities=
    efm.security.user.auth.groups.filter=.*
    efm.security.user.certificate.enabled=false
    efm.security.user.oidc.enabled=false
    efm.security.user.saml.enabled=false
    efm.security.user.knox.enabled=false
    efm.security.user.proxy.enabled=false
    # Database Properties (PostgreSQL Persistence)
    efm.db.url=jdbc:postgresql://ssb-postgresql.cld-streaming.svc:5432/efm
    efm.db.driverClass=org.postgresql.Driver
    efm.db.username=efm
    efm.db.password=efm_password
    efm.db.maxConnections=50
    efm.db.sqlDebug=false
    efm.db.l2CacheEnabled=false
    # Heartbeat Properties
    efm.heartbeat.maxAgeToKeep=0
    efm.heartbeat.persistContent=false
    efm.heartbeat.kafka.publishEnabled=false
    # Edge Event Retention Properties
    efm.event.cleanupInterval=30s
    efm.event.maxAgeToKeep.debug=0m
    efm.event.maxAgeToKeep.info=1h
    efm.event.maxAgeToKeep.warn=1d
    efm.event.maxAgeToKeep.error=7d
    # Agent Class Flow Monitor Properties
    efm.agentClassMonitor.interval=15s
    # Agent Monitoring Properties
    efm.monitor.maxHeartbeatInterval=5m
    efm.monitor.agentCertExpiryWarningInterval=30d
    # Operation Properties
    efm.operation.monitoring.enabled=true
    efm.operation.monitoring.inQueuedStateTimeoutHeartbeatRate=1.0
    efm.operation.monitoring.inDeployedStateTimeout=5m
    efm.operation.monitoring.inDeployedStateCheckFrequency=1m
    efm.operation.monitoring.rollingBatchOperationsFrequency=10s
    efm.operation.monitoring.rollingBatchOperationsSize=100
    efm.operation.monitoring.rollingOperationsSize.update.asset=10
    efm.operation.monitoring.rollingOperationsSize.update.configuration=100
    efm.operation.monitoring.rollingOperationsSize.update.properties=100
    efm.operation.monitoring.rollingOperationsSize.sync.resource=10
    # Bulletin Registry Properties
    efm.bulletinregistry.agentBulletinMaxAgeToKeep=5m
    efm.bulletinregistry.agentClassBulletinMinAgeToKeep=10s
    efm.bulletinregistry.agentClassBulletinMaxAgeToKeep=5m
    # Metrics Properties
    management.metrics.efm.enabled=true
    management.simple.metrics.export.enabled=false
    management.prometheus.metrics.export.enabled=true
    management.prometheus.metrics.export.descriptions=true
    management.metrics.enable.efm.heartbeat=true
    management.metrics.enable.efm.repo=true
    management.metrics.efm.enableTag.host=true
    management.metrics.efm.enableTag.protocol=false
    management.metrics.efm.enableTag.agentClass=true
    management.metrics.efm.enableTag.agentManifestId=true
    management.metrics.efm.enableTag.agentId=true
    management.metrics.efm.maxTags.agentClass=20
    management.metrics.efm.maxTags.agentManifestId=10
    management.metrics.efm.maxTags.agentId=100
    management.metrics.tags.application=efm
    management.metrics.distribution.percentiles.all=.75,.95,.99
    # Health and Info Properties
    efm.actuator.clusterHealthUpdateFrequency=10s
    efm.actuator.clusterInfoUpdateFrequency=1m
    management.endpoint.health.showDetails=never
    management.endpoint.health.showComponents=always
    management.health.refresh.enabled=false
    management.health.livenessstate.enabled=false
    management.health.readinessstate.enabled=false
    spring.cloud.discovery.client.compositeIndicator.enabled=false
    # EL Specification Properties
    efm.el.specifications.dir=./specs
    # Logging Properties
    logging.pattern.level=%5p [${spring.application.name:},%X{traceId:-},%X{spanId:-}]
    logging.level.com.cloudera.cem.efm=INFO
    logging.level.com.hazelcast=WARN
    logging.level.com.hazelcast.internal.cluster.ClusterService=INFO
    logging.level.com.hazelcast.internal.nio.tcp.TcpIpConnection=ERROR
    logging.level.com.hazelcast.internal.nio.tcp.TcpIpConnector=ERROR
    # General System Settings
    efm.data.transfer.maxFileSize=16MB
    efm.data.transfer.cleanupInterval=1h
    efm.data.transfer.maxAgeToKeep=1d
    efm.data.transfer.maxEntriesToKeep=100
    efm.agentManager.commands.displayLimit=20
    spring.main.banner-mode=log
    efm.asset.s3.downloadRootPath=/tmp/efm-asset-download
    efm.diagnosticBundle.enabled=false
    efm.agent-deployer.security.autoConfiguration=false
    efm.agent-deployer.security.ca.privateKeyPassword=
    spring.servlet.multipart.max-file-size=100MB
    spring.servlet.multipart.max-request-size=100MB
6. The Persistent Volume ClaimsPermalink
Save the following as efm-pvc.yaml. Two PVCs: one for agent installer binaries, one for uploaded resources like Python scripts and JARs.
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
spec:
  accessModes:
    - ReadWriteOnce
  resources:
    requests:
      storage: 2Gi
  storageClassName: standard
apiVersion: v1
metadata:
spec:
  accessModes:
    - ReadWriteOnce
  resources:
    requests:
      storage: 1Gi
Pro Tip! The efm-resources PVC is the one everyone forgets. Without it, uploaded scripts get tracked in the DB but the actual bytes vanish on restart — every flow that references an uploaded resource breaks.
7. The Deployment and ServicePermalink
Save the following as efm-deployment-persisted.yaml. This mounts both PVCs, mounts the ConfigMap on top of efm.properties, wires in the secrets as environment variables, and exposes EFM through a LoadBalancer service.
apiVersion: apps/v1
kind: Deployment
metadata:
  labels:
    app: efm
spec:
  replicas: 1
  selector:
    matchLabels:
      app: efm
  template:
    metadata:
      labels:
        app: efm
    spec:
      imagePullSecrets:
      - name: cloudera-registry
      containers:
      - name: efm
        image: container.repo.cloudera.com/cloudera/efm:2.3.1.0-2
        ports:
        - containerPort: 10090
        - containerPort: 9092
        env:
        - name: EF_DB_URL
          value: "jdbc:postgresql://ssb-postgresql.cld-streaming.svc:5432/efm"
        - name: EF_REGISTRY_URL
          value: "http://host.minikube.internal:18080"
        - name: EF_REGISTRY_ENABLED
          value: "true"
        - name: JAVA_OPTS
          value: "-Dspring.datasource.driver-class-name=org.postgresql.Driver -Def.db.driver.class.name=org.postgresql.Driver"
        - name: EF_JAVA_OPTS
        - name: EFM_DB_USER
          value: efm
        - name: EFM_DB_PASSWORD
          valueFrom:
            secretKeyRef:
              key: password
        - name: EFM_ENCRYPTION_PASSWORD
          valueFrom:
            secretKeyRef:
              key: encryption.password
        resources:
          requests:
            cpu: "250m"
            memory: "4Gi"
          limits:
            cpu: "250m"
            memory: "4Gi"
        volumeMounts:
        - name: agent-binaries
          mountPath: /opt/efm/efm-2.3.1.0-2/agent-deployer/binaries
        - name: efm-resources
          mountPath: /opt/efm/efm-2.3.1.0-2/resources
        - name: efm-config
          mountPath: /opt/efm/efm-2.3.1.0-2/conf/efm.properties
          subPath: efm.properties
          readOnly: true
      volumes:
        persistentVolumeClaim:
          claimName: efm-agent-binaries
          claimName: efm-resources
      - name: efm-config
        configMap:
apiVersion: v1
kind: Service
metadata:
  labels:
    app: efm
spec:
  type: LoadBalancer
  ports:
  - port: 10090
    targetPort: 10090
    protocol: TCP
  - port: 9092
    targetPort: 9092
    protocol: TCP
  selector:
    app: efm
8. Apply EverythingPermalink
Order matters — ConfigMap and PVCs first, deployment last:
kubectl apply -f efm-configMap.yaml -n cld-streaming
kubectl apply -f efm-pvc.yaml -n cld-streaming
kubectl apply -f efm-deployment-persisted.yaml -n cld-streaming
kubectl rollout status deployment/efm -n cld-streaming --timeout=180s
Quick sanity check that the ConfigMap actually mounted and that Postgres is in play (not H2):
EFM_POD=$(kubectl get pod -n cld-streaming -l app=efm -o jsonpath='{.items[0].metadata.name}')
kubectl exec $EFM_POD -n cld-streaming -- sh -c \
  'grep -E "db\.url|db\.driverClass" /opt/efm/efm-2.3.1.0-2/conf/efm.properties'
You should see jdbc:postgresql://.... If you see h2, the ConfigMap did not mount — re-apply and restart the deployment.
9. Route the LoadBalancer (Minikube Only)Permalink
Minikube needs a little help to assign an external IP. In a separate terminal, run:
minikube tunnel
Leave it running. If you want the port-forwards and tunnels managed nicely across a workspace, I covered that in my Using Kftray and Zellij post.
10. Access the UIPermalink
Open your browser and go to:
http://127.0.0.1:10090/efm/ui/
You are in. Create your first agent class, design a flow, publish it, and upload a resource — everything is now backed by Postgres and the two PVCs.
11. Prove the PersistencePermalink
The whole point of this exercise. Bounce EFM and confirm nothing disappears:
kubectl rollout restart deployment/efm -n cld-streaming
Refresh the UI. Your agent classes, your flows, and your uploaded resources should all still be there. Agents re-download their assets from the PVC-backed file on the next heartbeat.
For an even stronger test, run minikube stop and minikube start. Once EFM’s pod comes back Ready, everything reloads from Postgres and the PVCs automatically. Nothing to re-upload.
ResourcesPermalink
Cloudera Edge Flow Manager on KubernetesPermalink
If you would like a deeper dive, hands on experience, demos, or are interested in speaking with me further about Cloudera Edge Flow Manager on Kubernetes, please reach out to schedule a discussion.
Comments
Check out Cloudera's Edge To Ai for Dummies; a great read to pair with this article!!
https://stevenmatison.com/blog/Edge-to-AI-for-Dummies/
