Community Articles
Labels (1)
Expert Contributor
Pre-requisites
Process
Step 1: Install the [Impala ODBC Connector 2.7.0 for Cloudera Enterprise]
Step 2: Copy the ODBC folder to Power BI Desktop folder
Assume your Power BI Desktop is in [ C:\Program Files\Microsoft Power BI Desktop\ ], then please copy the ODBC Driver [ C:\Program Files\Cloudera ODBC Driver for Impala ] to [C:\Program Files\Microsoft Power BI Desktop\bin\ODBC Drivers\Cloudera ODBC Driver for Impala]
Step 3: Edit the config file
[ C:\Program Files\Microsoft Power BI Desktop\bin\ODBC Drivers\Simba Impala ODBC Driver.ini ]
[Simba Impala ODBC Driver]
# Oringinally PowerBI will use its embedded driver, we can change it to Cloudera version
# Driver=Simba Impala ODBC Driver\ImpalaODBC_sb64.dll
Driver=Cloudera ODBC Driver for Impala\lib\ClouderaImpalaODBC64.dll
# If you don't use SSL
SSL=0
Step 4: Run Power BI Desktop
If you want to use Windows AD Kerberos, then please don't install MIT Kerberos, and make sure you are using the Windows AD domain account to log in and run the Power BI Desktop application.
* Reference :
In the [Cloudera-ODBC-Connector-for-Impala-Install-Guide.pdf], it mentioned that,
  • Configuring Kerberos Authentication for Windows
  • Active Directory
    • The Cloudera ODBC Connector for Apache Impala supports Active Directory Kerberos on
      Windows. There are two prerequisites for using Active Directory Kerberos on Windows:
      • MIT Kerberos is not installed on the client Windows machine.
      • The MIT Kerberos Hadoop realm has been configured to trust the Active Directory realm,
        according to Apache's documentation, so that users in the Active Directory realm can
        access services in the MIT Kerberos Hadoop realm.
Step 5: Test Connection using ODBC
Open the [ODBC Data Source (64-bit)] application, and add a new DSN for testing.
I didn't use SSL, so I left the SSL un-checked.
For debug, you can set the log level to DEBUG.
As we will be using Kerberos to connect to Impala, please ensure that the AD server and DNS server are correctly configured.
Step 6: Fetch data in Power BI Desktop
In Power BI Desktop, use the [Get data -> more],
Input [Impala] to search for the connector,
Then, input the server info:
After that, you can use Windows Authentication (as Kerberos), input the
  • DOMAIN\account
  • password
Then you can see the window below:
At last, you can see the data after loading:
Comments
Dear all,
In this post, the Impala driver was installed, but the DSN was created using Hive drivers. Can you confirm whether Impala drivers cannot be used to create an ODBC DSN and if Power BI does not support it as ODBC?
Hi, @APentyala
Thanks for pointing out this.
Impala drivers also works well on this.
Both Impala and Hive drivers can work on this. I will replace the images so that it matches the descriptions 👍🏻
