Community Articles
Labels (1)
Cloudera Employee
Abstract
With native SQL Commands and the publically available Hivemall components we are able to build an advanced analytics and machine learning process for a recommendation system.
Setup the Environment
We will setup this environment with the latest version of the Hortonworks Sandbox and the Hivemall Repo as shown below to prepare our infrastructure for eg some relatively complicated Machine Learning concepts with a relatively simple environment.
Step 1- Download and install Hortonworks Sandbox HDP 3.0.1
Step 2 - Download the Hivemall artefacts Hivemall Repo and copy into your HDFS directory (so all nodes in the cluster have access to the same)
login as user: hive with the su -hive command
wget https://search.maven.org/remotecontent?filepath=org/apache/hivemall/hivemall-all/0.5.2-incubating/hi... -O hivemall-all-0.5.2-incubating.jar
hdfs dfs -mkdir /apps/hive/warehouse/lib
hdfs dfs -put hivemall-all-0.5.2-incubating.jar /apps/hive/warehouse/lib
Step 3A - Download DLL script from Github
wget https://raw.githubusercontent.com/apache/incubator-hivemall/v0.5.2/resources/ddl/define-all-as-perma... -O define-all-as-permanent.hive
Step 3B - Edit the first lines in the script by uncommenting the lines shown below and modifying the HDFS path:
vi define-all-as-permanent.hive uncomment (remove -- ) and modify/replace the following lines:
CREATE DATABASE IF NOT EXISTS hivemall;
USE hivemall;
set hivevar:hivemall_jar=hdfs:///apps/hive/warehouse/lib/hivemall-all-0.5.2-incubating.jar;
Step 4 - run the hive script define-all-as-permanent.hive to create the functions and create the Hivemall functions permanently
beeline -u "jdbc:hive2://sandbox-hdp.hortonworks.com:2181/;serviceDiscoveryMode=zooKeeper;zooKeeperNamespace=hiveserver2" -n hive --force=true -i define-all-as-permanent.hive
check that Hivemall function are available and lookup the version (don't worry if not all of the functions may have compiled, the ones necessary for this task should be there)
select hivemall.hivemall_version();
	|0.5.2-incubating |
Congratulations, now you ready to do the interesting part.
Building the Collaborative Filtering Recommendation System
This demo recommendation system is based on the two hypotheses:
  • co occurrence: customer repeatedly buying products that they have also bought previously
  • similarity: products bought with products together (think Amazon's "these products are often bought with")
The algorithms used are Item-based Collaborative Filtering and Naive similarity computation O(n^2) to compute all item-item pair similarity. In order to accelerate the procedure, Hivemall has an efficient scheme for computing Jaccard and/or cosine similarity.
We need to understand the available data and table structure in the foodmart database, and the two fact tables: sales_fact_1997 and sales_fact_1998 (for A/B testing) are necessary data for our recommendation system:
  • customers (customer_id)
  • products (product_id)
  • purchased quantity (count)
  • purchase date (time_id)
Table: sales_fact_1997
product_id time_id customer_id promotion_id store_id store_sales store_cost unit_sales
1318 483 3 1141 15 2.7900 0.8928 3.0000
970 697 3 0 15 9.3300 3.0789 3.0000
393 661 3 0 15 3.3600 1.4112 3.0000
885 483 3 1141 15 2.7600 1.0764 2.0000
1534 483 3 1141 15 5.5600 1.7792 2.0000
286 483 3 1141 15 4.2600 1.5336 3.0000
736 661 3 0 15 6.3900 3.0033 3.0000
1379 697 3 0 15 5.7600 2.8800 3.0000
130 483 3 1141 15 4.4600 1.3826 2.0000
1252 483 3 1141 15 6.8400 2.0520 3.0000
In the sandbox hive database the volume in these two tables is small only 86K rows and synthetically generated data, but good enough for demo purposes.
Change to the demo database foodmart.
use foodmart;
First we need to construct the customer_purchased table from the sales_fact_1997 table with the following parameters
  • customer_purchased (customer_id, product_id, purchased_at, purchase_count)
Aggregate the total count of purchased products for every customer that year.
CREATE TABLE customer_purchased as
select
 customer_id,
 product_id,
 max(time_id) as purchased_at,
 count(1) as purchase_count
from
 sales_fact_1997
group by
 customer_id,
 product_id
The elapsed runtime: 12 sec
Here is a snippet of what the expected customer_purchased table is expected to look like:
customer_idproduct_id purchased_atpurchase_count
15717201
45615341
91614631
131214891
227016981
344115901
Compute top-k recently purchased items for each user
Next we create the table with the top-k recently purchased items for each user like so:
create table recently_purchased_products ( rank int, purchased_at int, customer_id int, product_id int);
Here below is a brief explanation of the SQL commands used for this table creation:
-- where [optional filtering] -- purchased_at >= xxx -- divide training/test data by time
-- hivemall.each_top_k 5 --> get top-5 recently purchased items for each user
-- Note CLUSTER BY is mandatory when using each_top_k
INSERT OVERWRITE TABLE recently_purchased_products
SELECT
 hivemall.each_top_k( 5, customer_id, purchased_at, customer_id, product_id
	) as (rank, purchased_at, customer_id, product_id)
FROM (
  SELECT
    purchased_at,customer_id, product_id
  FROM
    customer_purchased
  CLUSTER BY
    customer_id
      ) t;
Here is a snippet of what the expected recently_purchased_products table is expected to look like:
customer_id rank product_id purchased_at
3 1 1379 697
3 1 204 697
3 1 1359 697
3 1 970 697
3 2 393 661
5 1 384 370
6 1 958 570
6 1 935 570
6 1 568 570
6 1 53 570
6 1 1417 570
10 1 1278 704
10 1 568 704
10 2 60 424
10 2 443 424
10 2 454 424
Cooccurrence-based Recommendation
In order to generate a list of recommended items, you can use either cooccurrence count or similarity as a relevance score. First, we look into the cooccurrence base method.
From the previous created table customer_puchased we create the table:
  • cooccurrence (product_id , other "product_id", count)
Group the "other" products that the same customer has purchased together. Basically two product_id's with count.
CREATE TABLE cooccurrence AS
SELECT
 u1.product_id,
 u2.product_id as other,
 count(1) as cnt
FROM
 customer_purchased u1
 JOIN customer_purchased u2 ON (u1.customer_id = u2.customer_id)
WHERE
 u1.product_id != u2.product_id
  AND u2.purchased_at >= u1.purchased_at
group by
 u1.product_id, u2.product_id
having
 cnt >= 2 -- count(1) >= 2
-- optional but recommended to have this condition where dataset is large cnt >= 2 -- count(1) >= 2
The elapsed runtime: 17 sec
A snippet of the data in the table cooccurrence:
TABLE cooccurrence
product_idother "product_id"count
1303
1423
1683
1742
1902
CREATE TABLE product_recommendation (customer_id int, rec_product array<int>);
From the above tables recently_purchase_products and cooccurrence we now select maximum the top five products ranked by count field as recommended products.
WITH topk as (
  select
       5, customer_id, cnt,
       customer_id, other
    ) as (rank, cnt, customer_id, rec_item)
  from (
    select
      t1.customer_id, t2.other, max(t2.cnt) as cnt
    from
      recently_purchased_products t1
      JOIN cooccurrence t2 ON (t1.product_id = t2.product_id)
    where
      t1.product_id != t2.other
      AND NOT EXISTS (
        SELECT a.product_id FROM customer_purchased a
        WHERE a.customer_id = t1.customer_id AND a.product_id = t2.other
         AND a.purchase_count <= 1
    group by
    CLUSTER BY
      customer_id
  ) t1
INSERT OVERWRITE TABLE product_recommendation
select
  customer_id,
  map_values(hivemall.to_ordered_map(rank, rec_item)) as rec_items
from
  topk
group by
  customer_id
The elapsed runtime: 44 sec
Now we have the recommended products for every customer, as shown in following snippet:
customer_id product_recommendation rec_product
3 [559,603]
5 [710,1326]
6 [202,623]
10 [1443]
14 [1333,1399]
17 [1420,1169,420]
19 [948,447,1368]
20 [1314,1374]
21 [535,1295]
23 [344,631]
Similarity-based Recommendation
Alternatively, it is possible to employ a similarity based recommendation, but for that we must go through a few extra steps. First we create a set of features for every product and apply the function hivemall consine_similarity to these product feature-pairs.
The products purchased together from the table co occurrence are concatenated into a column feature_vector.
CREATE TABLE product_features (product_id int, feature_vector ARRAY<string>);
INSERT OVERWRITE TABLE product_features
SELECT
 product_id,
 collect_list(hivemall.feature(other, cnt) ) as feature_vector
FROM
 cooccurrence
GROUP BY
 product_id;
Optional Tip: Adjust scaling `ln(cnt+1)` to avoid large value in the feature vector
Elapsed runtime: 15 sec
product_idfeature_vector : product_id:count, ...
1
["42:2","68:2","74:2","130:2","181:2","185:2" ... more
2["6:2","12:2","15:2","36:2","58:2","62:2","81:2" ... more
3["16:2","21:3","43:2","53:2","62:2","70:2","76:3" ... more
Basically, the next step is to compute the Cosine similarity for two products of their feature vectors. The computation required a significant amount of time (approx. 11 minutes).
CREATE TABLE product_similarity (product_id int, other in,  similarity double);
WITH similarity as (
 select
  t1.product_id,
  t2.product_id as other,
  hivemall.cosine_similarity(t1.feature_vector, t2.feature_vector) as similarity
 FROM
   product_features t1
 CROSS JOIN product_features t2
  WHERE
    t1.product_id != t2.product_id
 topk as (
   SELECT
      hivemall.each_top_k(3, product_id, similarity,product_id, other)
           as (rank, similarity, product_id, other)
   FROM (select * from similarity where similarity > 0 CLUSTER BY product_id) t)
INSERT OVERWRITE TABLE product_similarity
 SELECT product_id, other, similarity
 FROM topk;
Elapsed runtime: 674.603 sec
product_id product_similarity other similarity
1 201 0.19589653611183167
1 567 0.1647367626428604
1 644 0.1627947986125946
2 505 0.30411943793296814
2 455 0.29358285665512085
2 1360 0.2841376066207886
3 962 0.2816478908061981
3 1428 0.2689010500907898
3 629 0.2549935281276703
4 609 0.25717243552207947
4 620 0.24852953851222992
4 597 0.24722814559936523
5 548 0.2888334095478058
5 115 0.26622357964515686
5 481 0.26322928071022034
Final step is create the product_recommendation base on similarity that is calculate by hivemall.cosine_similarity.
WITH topk as (
  select
       5, customer_id, similarity,
       customer_id, other
    ) as (rank, similarity, customer_id, rec_item)
  from (
    select
      t1.customer_id, t2.other, max(t2.similarity) as similarity
    from
      JOIN product_similarity t2 ON (t1.product_id = t2.product_id)
    where
      t1.product_id != t2.other -- do not include items that user already purchased
      AND NOT EXISTS (
          AND a.purchase_count <= 1 -- optional
    group by
    CLUSTER BY
      customer_id -- top-k grouping by userid
  ) t1
select
  customer_id,
from
  topk
group by
  customer_id
Elapsed runtime: 20 sec
customer_id product_recommendation.rec_product
3 [376,1392,526,660,1336]
5 [544,883,1443]
6 [984,1501,66,358,1368]
10 [121,1546,984,1103,603]
14 [794,428,404,418,1416]
17 [334,111,24,1169,337]
19 [1202,447,1295,979,1152]
20 [968,43,432,952,1428]
21 [895,1295,1467]
23 [344,11,1423,1176,408]
Version history
Last update:
‎01-07-2019 07:27 PM
Updated by:
Contributors
