Community Articles
Labels (1)
Guru
kafka-python is best used with newer brokers (0.10 or 0.9), but is backwards-compatible with older versions (to 0.8.0). Some features will only be enabled on newer brokers, however; for example, fully coordinated consumer groups -- i.e., dynamic partition assignment to multiple consumers in the same group -- requires use of 0.9+ kafka brokers. Supporting this feature for earlier broker releases would require writing and maintaining custom leadership election and membership / health check code (perhaps using zookeeper or consul). For older brokers, you can achieve something similar by manually assigning different partitions to each consumer instance with config management tools like chef, ansible, etc. This approach will work fine, though it does not support rebalancing on failures. See <http://kafka-python.readthedocs.org/en/master/compatibility.html> for more details.
Please note that the master branch may contain unreleased features. For release documentation, please see readthedocs and/or python's inline help.
>>> pip install kafka-python
KafkaConsumer
KafkaConsumer is a high-level message consumer, intended to operate as similarly as possible to the official java client. Full support for coordinated consumer groups requires use of kafka brokers that support the Group APIs: kafka v0.9+.
See <http://kafka-python.readthedocs.org/en/master/apidoc/KafkaConsumer.html> for API and configuration details.
The consumer iterator returns ConsumerRecords, which are simple namedtuples that expose basic message attributes: topic, partition, offset, key, and value:
>>> from kafka import KafkaConsumer
>>> consumer = KafkaConsumer('my_favorite_topic')
>>> for msg in consumer:
...     print (msg)
>>> # manually assign the partition list for the consumer
>>> from kafka import TopicPartition
>>> consumer = KafkaConsumer(bootstrap_servers='localhost:1234')
>>> consumer.assign([TopicPartition('foobar', 2)])
>>> msg = next(consumer)
>>> # Deserialize msgpack-encoded values
>>> consumer = KafkaConsumer(value_deserializer=msgpack.loads)
>>> consumer.subscribe(['msgpackfoo'])
...     assert isinstance(msg.value, dict)
KafkaProducer
KafkaProducer is a high-level, asynchronous message producer. The class is intended to operate as similarly as possible to the official java client. See <http://kafka-python.readthedocs.org/en/master/apidoc/KafkaProducer.html> for more details.
>>> from kafka import KafkaProducer
>>> producer = KafkaProducer(bootstrap_servers='localhost:1234')
>>> for _ in range(100):
...     producer.send('foobar', b'some_message_bytes')
>>> # Block until all pending messages are sent
>>> producer.flush()
>>> # Block until a single message is sent (or timeout)
>>> producer.send('foobar', b'another_message').get(timeout=60)
>>> # Use a key for hashed-partitioning
>>> producer.send('foobar', key=b'foo', value=b'bar')
>>> # Serialize json messages
>>> import json
>>> producer = KafkaProducer(value_serializer=lambda v: json.dumps(v).encode('utf-8'))
>>> producer.send('fizzbuzz', {'foo': 'bar'})
>>> # Serialize string keys
>>> producer = KafkaProducer(key_serializer=str.encode)
>>> producer.send('flipflap', key='ping', value=b'1234')
>>> # Compress messages
>>> producer = KafkaProducer(compression_type='gzip')
>>> for i in range(1000):
...     producer.send('foobar', b'msg %d' % i)
Compression
kafka-python supports gzip compression/decompression natively. To produce or consume lz4 compressed messages, you must install lz4tools and xxhash (modules may not work on python2.6). To enable snappy compression/decompression install python-snappy (also requires snappy library). See <http://kafka-python.readthedocs.org/en/master/install.html#optional-snappy-install> for more information.
Protocol
A secondary goal of kafka-python is to provide an easy-to-use protocol layer for interacting with kafka brokers via the python repl. This is useful for testing, probing, and general experimentation. The protocol support is leveraged to enable a KafkaClient.check_version() method that probes a kafka broker and attempts to identify which version it is running (0.8.0 to 0.10).
Comments
Expert Contributor
Hi,
I am trying to connect from local machine to a kerberized kafka cluster through python as python client, could you please let me know what all the properties to include along with bootstrap server ?
consumer = KafkaConsumer('test',bootstrap_servers='XXX.ORG:XXXX',
#client_id= kafka-python- + __version__,
request_timeout_ms=30000,
connections_max_idle_ms=9 * 60 * 1000,
reconnect_backoff_ms=50,
reconnect_backoff_max_ms=1000,
max_in_flight_requests_per_connection=5,
receive_buffer_bytes=None,
send_buffer_bytes=None,
#socket_options= [(socket.IPPROTO_TCP, socket.TCP_NODELAY, 1)],
sock_chunk_bytes=4096, # undocumented experimental option
sock_chunk_buffer_count=1000, # undocumented experimental option
retry_backoff_ms=100,
metadata_max_age_ms=300000,
security_protocol='SASL_SSL',
ssl_context=None,
ssl_check_hostname=True,
ssl_cafile=None,
ssl_certfile=None,
ssl_keyfile=None,
ssl_password=None,
ssl_crlfile=None,
api_version=None,
api_version_auto_timeout_ms=2000,
#selector=selectors.DefaultSelector,
sasl_mechanism='GSSAPI',
#sasl_plain_username= None,
#sasl_plain_password='XXXX',
sasl_kerberos_service_name='XXXX',
# metrics configs
metric_reporters=[],
metrics_num_samples=2,
metrics_sample_window_ms=30000)
Your help is appreciated.
Thanks
Version history
Last update:
‎02-02-2017 03:38 PM
Updated by:
Contributors
