Created on
05-15-2024
05:34 AM
- last edited on
04-20-2026
11:30 PM
by
GrazittiAPI
Dear Friends
The concerned Cloudera Services are:
Spark 3 , Livy for Spark 3, Hue
After I have added Spark SQL interpreter in Hue I am struggling to get more than 1000 rows results once querying the DB. Do you know what parameter should be used to change the default quantity. I Already tried to use :
spark.livy.sql.max-result
CM --> Livy for Spark3 --> Search for "Livy for Spark 3 Client Advanced Configuration Snippet (Safety Valve) for livy3-conf/livy-client.conf" and add the above parameter with value.
spark.livy.sql.max-result=2000
However after restarting the concerns services - nothing has changed. Hereunder you can see what is all about:
I would like to change this limitation to e.g. 5000. But not sure on what mentioned services this should be adjusted on.
I really appreciate your help in this.
Thank you
Created 05-15-2024 11:53 PM
Hi @Bartlomiej
You can use livy.rsc.sql.num-rows parameter to adjust the number of rows wants to display.
CM --> Livy for Spark3 --> Search for "Livy Server for Spark 3 Advanced Configuration Snippet (Safety Valve) for livy3-conf/livy.conf" and add the above parameter with value.
livy.rsc.sql.num-rows=5000
I have created a test_3000 table by inserting 1 to 2999 records. While running the query from Hue Spark3 editor you can see the following output:
Created 05-15-2024 07:57 AM
@Bartlomiej, Welcome to our community! To help you get the best possible answer, I have tagged our Spark experts @RangaReddy @Babasaheb @ggangadharan who may be able to assist you further.
Please feel free to provide any additional information or details about your query, and we hope that you will find a satisfactory solution to your question.
Regards,
Vidya Sargur,Created 05-15-2024 11:53 PM
Hi @Bartlomiej
Created 05-16-2024 02:59 AM
Yes, this is it.
Thank you so much for the prompt response.
