Support Questions
We’ve updated our product names and community labels - click here for full details
Issue of copying data from kudu to hdfs using spark sql
I have a kudu table with schema:
create table test_table
    `time` timestamp not null, --
    `id` string not null, --
primary key(`time`,`id`)
partition by hash(id) partitions 6
stored as kudu;
and I try to use spark to copy the data to a parquet table in hdfs:
 val df = spark.read.options(Map("kudu.master" -> kuduMasters,
        "kudu.table" -> KuduTable)).format("kudu").load
        .where("time> '2019-10-29 08:05:10' AND time < '2019-10-29 08:05:30'")
 df.write
        .mode("append")
        .parquet("hdfs://parquet")
But the performance is low and the job seems to be doing a full table scan against the kudu table (from spark UI, I can see the "Scan Kudu impala::table" is the number of entire table).
For comparison I did a copy using impala's "insert into from" which is much faster and the "where" predicate seems to be working.
Is this full table scan behavior expected or am I missing something here? The kudu version is 1.10.0 and spark client is kudu-spark2_2.11:1.10.0
1 ACCEPTED SOLUTION
Cloudera Employee
Can you try explicitly casting the string value to a timestamp?
I don't think Spark will push down the timestamp predicate if it's a string. This is tracked in https://issues.apache.org/jira/browse/KUDU-2821.
2 REPLIES 2
Cloudera Employee
Hi @Grant Henke
The timestamp predicate works after I cast it to timestamp, thank you for your help!
