Created 02-16-2017 11:11 AM
I enabled kerbosr in sandbox HDP 2.5, but fails to start hive metastore.
This is the princpal setting:
hive.server2.authentication.kerberos.principal hive/_HOST@EXAMPLE.COM
hive.metastore.kerberos.principal hive/_HOST@EXAMPLE.COM
here's the log I see
2017-02-16 11:05:56,541 ERROR [main]: metastore.HiveMetaStore (HiveMetaStore.java:startMetaStore(6326)) - org.apache.thrift.transport.TTransportException: Kerberos principal should have 3 parts: hive at org.apache.hadoop.hive.thrift.HadoopThriftAuthBridge$Server.createTransportFactory(HadoopThriftAuthBridge.java:351) at org.apache.hadoop.hive.metastore.HiveMetaStore.startMetaStore(HiveMetaStore.java:6244) at org.apache.hadoop.hive.metastore.HiveMetaStore.main(HiveMetaStore.java:6155) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.apache.hadoop.util.RunJar.run(RunJar.java:233) at org.apache.hadoop.util.RunJar.main(RunJar.java:148) 2017-02-16 11:05:56,542 ERROR [main]: metastore.HiveMetaStore (HiveMetaStore.java:main(6159)) - Metastore Thrift Server threw an exception... org.apache.thrift.transport.TTransportException: Kerberos principal should have 3 parts: hive at org.apache.hadoop.hive.thrift.HadoopThriftAuthBridge$Server.createTransportFactory(HadoopThriftAuthBridge.java:351) at org.apache.hadoop.hive.metastore.HiveMetaStore.startMetaStore(HiveMetaStore.java:6244) at org.apache.hadoop.hive.metastore.HiveMetaStore.main(HiveMetaStore.java:6155) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.apache.hadoop.util.RunJar.run(RunJar.java:233) at org.apache.hadoop.util.RunJar.main(RunJar.java:148)
Created 02-16-2017 11:53 AM
@jzhang From the error its suspected that you have not properly defined principal name in configs -
Can you please revisit the configs again
"Kerberos principal should have 3 parts: hive"
It should be - "hive/_HOST@REALM"
Check properties below in HIVE configs -
hive.server2.authentication.kerberos.principal hive.metastore.kerberos.principal
Created 02-16-2017 12:48 PM
Here's the setting:
Created 02-16-2017 11:55 AM
Here's the setting:
Created 02-16-2017 10:49 PM
@jzhang The _HOST in the principal name gets replaced by the fully qualified domain name of the host at runtime. However, this needs the reverse DNS to be configured correctly on the box. Could you check that?
Created 02-17-2017 01:07 AM
I think it is correct, here's the file /etc/hosts
127.0.0.1 localhost sandbox.hortonworks.com ::1 localhost ip6-localhost ip6-loopback fe00::0 ip6-localnet ff00::0 ip6-mcastprefix ff02::1 ip6-allnodes ff02::2 ip6-allrouters
Created 03-06-2017 07:02 AM
Any update on this ? This issue is a pretty bad experience.
Created 03-06-2017 07:31 AM
What's the output of "hostname" and "hostname -f" commands on your host where the error occurs? Also, cd to /etc/security/keytabs and run: "klist -kt hive.service.keytab", I suspect the principal stored in the keytab is wrong.
Created 03-07-2017 06:16 AM
Output of klist
4 03/07/17 03:25:16 hive/sandbox.hortonworks.com@EXAMPLE.COM
Output of hostname -f
