Support Questions
Problem with Impala ODBC Parameter Values and Prepared Statements
Hi, I'm trying to connect via unixODBC and Cloudera Impala driver.
I managed to retrieve data with some simple queries.
As soon I use prepared statements, seems Impala driver can not handle it.
Jun 22 22:23:38.596 ERROR 749795712 Simba::ODBC::ClassicQueryExecutor::Execute: [Cloudera][ODBC] (10920) No data can be obtained from an input parameter whose value has already been pushed down.
Jun 22 22:23:38.601 ERROR 749795712 Simba::ODBC::StatementState10::SQLParamData: [Cloudera][ODBC] (10920) No data can be obtained from an input parameter whose value has already been pushed down.
My code is a simple snippet for now for testing, I could track the parameter inunixODBC side, seems Impala driver can not map them somehow.
I appreciate any help on this.
1 REPLY 1
Community Manager
Welcome to the community @samans
I'm not an expert but I did some searching and may have found something for you. I would review the Cloudera ODBC Connector for Apache Impala documentation as I see some references to transaction statements not being supported and how to work around it. Not sure if that is the issue here, but hope it helps.
Cy Jervis, Manager, Community Program
