Support Questions
problem with nifi listFTP offset
New Member
Hi, I'm in trouble with listftp processor, I need to process each new file on a FTP server, fetch and move to new folder with the date (year/month/day). sometimes listFTP offset reach the last file but the fetch doesn't move the file without errors and files start to accumulate. I can't fetch the file and move it because fetch doesn't create folder if doesn't exist, for this reason i used a putftpfile.
Somebody experienced the same problem?
1 ACCEPTED SOLUTION
Master Mentor
@federico dell'anese
The particular enhancement you are looking for here was coded in to Apache NIFi 1.7.0 version. Upgrading to this new version of NiFi will allow the FetchFTP processor to create move directories dynamically. The change was covered in the following Apache Jira:
https://issues.apache.org/jira/browse/NIFI-5090
Thank you,
Matt
If you found this Answer addressed your original question, please take a moment to login and click "Accept" below the answer.
2 REPLIES 2
Master Mentor
Thank you,
Matt
New Member
thanks Matt, it solves the problem 🙂
