Support Questions
Are vertex_index, edge_index and fulltext_index collections used for indexing in Atlas?
Rising Star
I am using the following guide (link: http://atlas.incubator.apache.org/InstallationSteps.html) for building and installing Atlas.
In the guide the user needs to create three collections in Solr, vertex_index, edge_index and fulltext_index. I would like to know what is the purpose of these and how do they work in order to index?
Also, how does indexing work in Atlas?
Thanking you in anticipation.
1 REPLY 1
Expert Contributor
These following are the SOLR indexes that Atlas typesystem use:
  1. vertex_index - A mixed index - fields like guid, type, timestamp and state are indexed so they can be used in any combination during search query.
  2. edge_index - We don't use this index much in Atlas, this is added to enable indexing on edge properties.
  3. fulltext_index - used for fulltext search. The indexed fields (entityText) are tokenized to enable faster retrieval.
To know more about how indexes work in Atlas: http://s3.thinkaurelius.com/docs/titan/0.5.4/indexes.html
Hope this helps.
